17th December 2015, 12:39 PM
Ceramic Tyre Beads
Just had five 285XR75X16 Maxxis 980 AT's fitted. The tyre guy talked me into using ceramic beads instead of wheel weights. I was not sure they would work on larger tyres but they are brilliant. Just went for a run around town and also on the freeway varying the speed from zero to 110 kph and there is no vibration at all. The best thing is that in theory the tyres should never need rebalancing, as they rebalance themselves continuously. Also, I don’t have to worry about weights coming unstuck on the mags.
Good so far. I guess time will tell.
The Following 6 Users Say Thank You to BillsGU For This Useful Post:
abw (14th January 2017), BigRAWesty (17th December 2015), Bob (17th December 2015), Clunk (17th December 2015), jay see (17th December 2015), my third 256 (19th December 2015)
17th December 2015 12:39 PM
17th December 2015, 12:49 PM
let us know after a good run in the bush uneven roads and pot holes
The Following User Says Thank You to Sir Roofy For This Useful Post:
17th December 2015, 12:51 PM
BillsGU
Nice one. I was toying with the idea aswell.
They should work well on larger tyres as a lot of trucks run them, but mainly motor bikes.
17th December 2015, 01:24 PM
Interested in this.
Have requested details from my Tyre Supplier.
17th December 2015, 01:36 PM
They sit in the bottom of your tyre when stationary and balance up the tyre every time you move.
If a tyre shop cant balance your tyre correctly he's in the wrong game. Most 4x4s that use these "beads"
run Centipede tyres which after a while are a rat to balance
17th December 2015, 02:44 PM
Video demonstrating Tyre Beads
http://www.abcbeads.com.au/#!video-demo/ci59
and how they work
http://www.abcbeads.com.au/#!how-they-work/c1qc9
It is going to cost me just under $100 to have 5 Tyres fitted through Bob Jane (Bendigo)
Will let you know my thoughts after I use for a period of time
The Following 3 Users Say Thank You to Bob For This Useful Post:
BigRAWesty (17th December 2015), BillsGU (18th December 2015), Clunk (17th December 2015)
17th December 2015, 02:53 PM
What minimum speed do they work at? At slow speeds are they effective?
17th December 2015, 02:57 PM
sooty_10
Not sure but Bill says he has tested through the speed range with good results.
Will let you know
17th December 2015, 03:42 PM
It depends on the size of the shot as to when they ballance.
The smaller the shot the lighter the weight the sooner they ballance.
17th December 2015, 04:12 PM
Do they shot blast the paint off the inside of the rim?
