Page 2 of 91 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 904
    Heres what the relay box looks like underneath.
    And heres the box with the new bases in. Not wired in yet. The looms are just tucked away for now. Next job is to wire them in.
    Western suburbs of Melbourne
    11 Post(s)
    Aren't you a busy boy.
    Looks great.
    Great use of space.
  4. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    mudski (11th December 2015)
  5. #13
    Yo Mark have you fitted your scoop yet?
    If not could you trace the outline and bolt holes
    on a sheet of paper for me please
    Hoping its the same as Rockets and Eric's?
    [Fairlaine]
  6. #14
    [Fairlaine]
    Yeah mate scoop was fitted yonks ago... Rocket has the same scoop as me, Fairline, and Eric has the OEM scoop. What do you need the trace for?
  7. #15
    Was going to laser cut some aluminium to make a vane to direct air to the front of the IC
    similar to the A.R.E. scoop
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #16
    Getting a bit further down the wiring track with the Relays. I have done 3, horn, angel eyes and devil eyes. I have left is the spotties and then the two for the fuel pump. Thanks to John,jff45, for the assistance in the how too's of running the relays for this.
    I'm also running a separate fuse box (pictured) just for the power supply to the relays.
    Then once its all wired, its time to fit the pump up, then the brakes go in...
  10. #17
    Finally finished the relay box wiring. I have one spare spot in there too. I was going to put the two relays for the lift pump in there but they are wire differently to usual and I had pre wired the relays in there so I mounted them down next to the brake booster....So the lift pump wiring is all in too, I just need to plumb up the pump at the back and thats another mod to tick of the list...
    I'm quite chuffed with the relay box job really. Its so much neater now.
    mudnut (16th December 2015)
  12. #18
    Finally finished installing the lift pump. It now operates only when the oil pressure switch has switched of after the engine has started.
  13. The Following 5 Users Say Thank You to mudski For This Useful Post:
    Hodge (21st December 2015), jff45 (22nd December 2015), mudnut (21st December 2015), Rossco (21st December 2015), Sprock (3rd January 2016)
  14. #19
    The TB calipers, discs and backing plates are in... also a new front right hub. Now to replace the brake line from the t junction and the master cylinder.
  15. The Following 4 Users Say Thank You to mudski For This Useful Post:
    AB (3rd January 2016), BigRAWesty (3rd January 2016), Rossco (3rd January 2016), Sprock (3rd January 2016)
  16. #20
    43 Post(s)
    Looks like a race car...
    But looks good
  17. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    bsteveo (4th January 2016), mudski (3rd January 2016)
