Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: Stabaliser or not
  1. #51
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hahah, you know us cleva GU drivers, always looking for an invention to break the technology barriers.
    Yeah you guys weren't scared to launch into the new world of plastic either.
    But seriously, if you were going to do a conversion, it would have to be easier to just stick with the lever set up rather than pumps and servos and actuators?
    tappin from tassie
    Hello from Under Down Under!
    465 Post(s)
    tappin from tassie
    I just pulled up a VIN from a Euro spec GRX. Its got factory rear stabilizer release. Now to work out a parts list. Lol I bet this will turn out to be an expensive list.
    BigRAWesty (11th December 2015)
  5. #53
    Aug 2011
    North West Tas
    56 Post(s)
    Push button? Or lever?
    tappin from tassie
  6. #54
    465 Post(s)
    tappin from tassie
    All electric mate. Just did a rough calculation. It will cost me around 3.5K in parts if I bought them new. I think I will leave this one for now.
    taslucas (11th December 2015)
  8. #55
    43 Post(s)
    So a couple of pictures.
    To fit the gq setup you'll need to get the chassis bracket and change them over.
    So some cutting and welding required.
    So the t handle.
    It's a simple cable exactly like the old ford T handle hand brakes..
    Next is the main unit. As you can see its quite a a different bracket so I'd say this is the critical bit..
    The wires are simply a sensor for the dash light..
    And just for comparison a stock bracket
  9. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    AB (11th December 2015), MudRunnerTD (11th December 2015), mudski (11th December 2015)
  10. #56
    583 Post(s)
    Or just buy a real 4wd and be done with it...
  11. The Following 3 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (11th December 2015), Clunk (11th December 2015), Winnie (11th December 2015)
  12. #57
    465 Post(s)
    Already have a real 4wd. Just toying with ideas...
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    AB (11th December 2015), BigRAWesty (11th December 2015)
  14. #58
    43 Post(s)
    So flicking threw the gu manual and came across this..
    So they must have an option for it somewhere..
    You should remove the disconnect from the GQ mate. I have a kit in my shed that I gave never got around to fitting to the GU. Would be simple enough though I reckon.
  16. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (1st January 2016)
  17. #60
    43 Post(s)
    Hmmmmmmm. . Your probably right..
