1st December 2015, 11:40 AM
#71
12v only , led lights only turned on when needed, cooking etc , i just like to keep it simple , bit like me !
1st December 2015 11:40 AM
1st December 2015, 12:43 PM
#72
gaddy
That's the reason for the longevity of the aux batteries. LEDs don't consume lot of power. If you try to run the fridge for four days without charging the batteries they won't last anywhere near four days, hence the reason for the preference of solar as a backup.
1st December 2015, 01:36 PM
#73
Fridge only runs off the car , half hour - hour drive each day , got told years ago by fridgies i worked with years ago remove the travel bag from the fridge , ( would you wear a jumper when its hot )1 cold beer out 1 hot beer in , sweet as
The Following User Says Thank You to gaddy For This Useful Post:
dom14 (1st December 2015)
1st December 2015, 01:40 PM
#74
gaddy
I must do something wrong ! I run a fridge (old engel ) charge phones , dvd players for the kids , charge the van battery , run lights and shower pump , 1oo amp alt cheap projector vsr , 90 amp deep cycle as a second battery and same in the van hooked up via anderson plug when towing , and can sit for to 4 days with out even getting close to killing batteries , and get around 5- 7 years battery life , i do plug into a cetec charger at home to keep them conditioned , no solar ,
Should add usually go for a drive most days for maybe 1hr all up ,
Sorry to break the news to you, but you're doing everything right.
The Following User Says Thank You to dom14 For This Useful Post:
gaddy (1st December 2015)
1st December 2015, 01:46 PM
#75
For what it's worth spent 3 and a half days at birdsville in September, only time the car moved was to spend a sun set on big red maybe 1.5 hrs drive time , no dramas at all , put a hot ctn of beer and a slab of bundy cans through the fridge as well
1st December 2015, 03:55 PM
#76
gaddy
What was the midday temperature in Birdsville when you were there in September? Mild or hot?
1st December 2015, 06:59 PM
#77
Low 30s
