Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Winch solenoid mounting.
    Expert King_ady1's Avatar
    Beveridge, Victoria
    Hey guys. Just looking for people's mounting ideas and locations for the solenoid box...
    My hesitation points.
    Although it's suppose to be waterproof... I would prefer it up under the bonnet to keep it out of those big holes just incase.
    But how far away would be maximum to avoid power loss??
    Any pics on mounting locations would be great.
    I'm planning on moving the control plug to a convenient location. And have controls in car. So that won't be a problem.
    Cheers.
    Adrain.
    465 Post(s)
    Mine is mounted to the winch motor. So its all hidden.
    175 Post(s)
    Mine sat between the grille and the rad on my crd. Ill post up a photo later on.
    Tapatalked from S6
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    This is a thread I did a while back. There are several pics of how I located mine behind the battery and installed the plug in the cabin..
    http://www.nissanpatrol.com.au/forum...h-alloy-bumper
    John
    Beveridge, Victoria
    Thx guys. Nice one Jff, beautiful job. I think my box was a bit big for that gap behind the battery. But I'll investigate bit more when I get home.
    175 Post(s)
    Here is a few pics of where I put mine mate. First pics shows where it was on the common bullbar position. And the second one shows where it ended up. It sat between the radiator and the grille bracket. The grille has a plastic bracket thats attached to it, which sits between this metal bracket on the car and the grille (if that made sense lol, sorry already 3 stubbies down). You remove this bracket off the grilee itself and it gives you room for the solenoid box. Hidden behind and tucked away. However I had a remote control for this, but still could reach down and plug in the wired remote if needed.
    Yeah so have I.
  9. The Following User Says Thank You to Winnie For This Useful Post:
    Stropp (26th November 2015)
  10. #8
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Yeah so have I.
    Any excuse to show it all off again! Hahah
  11. The Following User Says Thank You to Bacho86 For This Useful Post:
    Rossco (26th November 2015)
  12. #9
    Beveridge, Victoria
    Ok... So taking a look under the hood and I can't see too much room for this basterd to fit. It's a large thing
    This is what I'm working with....
    This is the only real spot I can see to mount without moving everything and squeezing it in somewhere...
    Does any1 see any real issues with mounting it up here?? Heat from exhaust??
    If this doesn't work I might just mount in bull bar or grill area.
    Cheers again.
  13. #10
    Quote Originally Posted by King_ady1 View Post
    Cheers again.
    It's a long way from the winch, ideally you want it as close as possible.
    I would definitely put it in the grille or bar if that is an option.
