21st November 2015, 11:12 PM
A little overwhelmed, would appraciate some clarification about WLL
Hi all,
I was looking at buying some rated recovery points for my Patrol GU III.
I've started doing some research online to get an idea of the price range, but I'm not really sure if the ones I found are rated high enough. They list a WLL of 5 tonnes, and my car will probably end up weighing around 3.1 tonnes. However, I'm not quite sure if I should be adding a buffer..
21st November 2015 11:12 PM
21st November 2015, 11:26 PM
your WLL - will be determined by things like
stuck in mud
stuck in sand
stuck in water
etc
if you fire off a PM (private message) to Threedogs - he manufactures them - and they are a good bit of kit
22nd November 2015, 12:14 AM
22nd November 2015, 03:03 AM
Patrol Goddess
Bigcol
stuck in mud
stuck in sand
stuck in water
etc
But give him a few days as he is laid up in hospital ATM.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
22nd November 2015, 07:36 AM
WLL is a working load limit...
As above, pm threedogs from outback ideas for them.
http://www.nissanpatrol.com.au/forum...ad.php?t=12616
Same price as your eBay sets, but uses quality aus steel and he tests the designs to 16+ tones before they get sold..
22nd November 2015, 01:45 PM
WLL is a lifting term and doesnt really have much bearing in snatching 4x4 terms,
Its the same as SWL , why ppl would want to over rate something the Manufacturer says
is beyond me.
My points are rated to tow at your max towing capacity all dat long. but heaps has been written on it
so PM sent.
Until someone comes up with a STD it may be all we have.
The Following 3 Users Say Thank You to threedogs For This Useful Post:
BigRAWesty (22nd November 2015), outback (22nd November 2015), Woof (22nd November 2015)
22nd November 2015, 06:55 PM
Like everyone has said get them of threedogs.
Also get one per side AND remember to use high tensile bolts.
