18th November 2015, 06:24 AM
Patrol Guru
Sex Positions.
Now that I have your attention people.
When ever I turn my A/C on I get the very strong smell of auto trans fluid coming out of the vents for a couple of minutes. Any theories?
98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
"GO YOU CROWS"
The Following User Says Thank You to Chubba For This Useful Post:
growler2058 (1st November 2018)
18th November 2015 06:24 AM
18th November 2015, 06:39 AM
Patrol Guru
I'd say condensation and then the growth and build up of mould in the vents. You can probably get some spray to help, but I'd be running the air con all the time for a while (read weeks) to dry it out. For the record, I can't remember the last time I turned mine off.
Cheers Rod
My Build 2005 TD42TI
18th November 2015, 06:49 AM
Patrol Guru
I run mine almost every day of the year. And the smell is ATF not a mouldy smell. Is the intake for the A/C the grill under the windscreen?
"GO YOU CROWS"
18th November 2015, 07:18 AM
Patrol Guru
There goes that theory then... I'm not sure whwre the air con gets it's air from.
Cheers Rod
18th November 2015, 10:01 AM
You Verrry funny.
Turn the fan on & put your air on recycle, then spray well with glen-20, directly into the air intake under the dash.
this will kill the germs causing the odour.
you may need to repeat a couple of times depending on how bad the cooler is blocked up with gunk.
dust, hair build up inside the cooling unit.
you may want to do this annually as a preventative maintenance.
I came across this advice on here, it works well.
my only concern was the possibility of spark from fan motor catching the spray alight.
Have done this a few times now over a number of years, with no problem.
Maybe before you start, turn off all red lights!!.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
The Following User Says Thank You to Robo For This Useful Post:
Chubba (18th November 2015)
18th November 2015, 06:50 PM
I am he, fear me
Chubba
If the problem persists you may have to do away with your current unit and resort to a (cough, cough) manual conversion
It is not uncommon for difficulty in getting some pairings up to equal operating status simultaneously
The Following 4 Users Say Thank You to the evil twin For This Useful Post:
Bigcol (18th November 2015), Chubba (18th November 2015), Robo (19th November 2015), Stropp (18th November 2015)
18th November 2015, 07:25 PM
Check that your heater core is not leaking.
The Following User Says Thank You to Yendor For This Useful Post:
