Page 8 of 8 FirstFirst ... 678
Results 71 to 77 of 77
Thread: Which solar panel to buy
  1. #71
    do you just spread them over the roof of your van and Patrol
    The 4 x 25's are in a folding canvas bag with clears on the pockets so I treat it like "normal" ones and pop 'em in teh sun as I like to have the Van in the shade.
    The 2 x 50's are seperate... don't usually need them but if I do then I just chuck 'em wherever IE on the roof basket of the Ute etc.
    At home I might have 1 x 50 keeping the Ute up to charge and 1 x 50 doing the same for the van and the 25's packed away
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    threedogs (15th October 2015)
    Quote Originally Posted by Ronin View Post
    my plan (in theory) to skip the whole dual battery setup completely.
    I have a cheap AGM deep cycle that was given to me. SO when I am driving I will have the fridge/freezer connected to the rear 12v cig socket that runs off main battery. Once I am at camp site, I will plug it into the spare deep cycle and connect the solar to the battery via a mppt controller.
    Something that I should look into.
    Pros and cons, this set up vs dual battery?
  5. The Following User Says Thank You to jay see For This Useful Post:
  6. #73
    Start a thread I think you get good info good and bad.
    Id be interested in what ppl think
  7. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (15th October 2015), jay see (15th October 2015)
  8. #74
    We do, but a bit later.
  9. #75
    Expert Ronin's Avatar
    Brissy
    PROs
    - Simplicity: no mucking around as its easy DIY (dont need auto leccy)
    - Cost savings: the whole thing would cost me about 350 as compared to about atleast 500 to 1000 for battery isolator and other bits and pieces and even more if I go for a decent BMS. More money if installed by a auto leccy. Dont need massive AH battery.
    - Long runtime: Potentially unlimited run time with decent sunny days and correct placement.
    - Future proof: Can add a dual battery system down the line if I feel the need and wont have to throw any existing bits away.
    - Light weight dont need super massive battery for this setup.
    CONs
    - cant wire up accessories like UHF or light bar to it easily.
    - needs manual cut over from crank battery to the spare deep cycle when u reach camp site.
    On a average we go once a month camping for about 3 nights max so this setup should work for us.
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  10. The Following 2 Users Say Thank You to Ronin For This Useful Post:
    jay see (15th October 2015), threedogs (16th October 2015)
  11. #76
    PROs
    CONs
    Thanks Ronin.
    I've set up a thread for this.
  12. #77
    Jan 2016
    I have a thin film amorphous panel 122W that seems to do the trick. It's a bit heavy and lives in our van most of the time, but not much in overheads and runs a SunTech solar controller from the dual battery. Runs the fridge mostly (with ease). The best we got out of it was 7.8 amps.
