Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Some td42 pics
    22 Post(s)
    Some td42 pics
    Here is some pics of my fresh motor. It was supposed to go in this weekend but I have been working interstate and just got back. It's fully balaced, the rotating assembly is balanced to 0.01g and the pistons and rods etc are individually balanced to 0.0002g. It has ceramic coated genuine UD pistons and turbo oil pump.
    Sticking with the garrett for now. I want to see what the engine mods can do for it.
    The flywheel has been lightened in an effort to move the deadly harmonics that contribute to crank failure out of the useable rev range.
    The exhaust manifold, turbine housing, v-band flange are ceramic coated. The manifold, turbine housing and wastegate port have been ported
    The head has oversize valves with a 4 angle grind, ceramic coated pre combustion chambers inside and out, the face of the valves and combustion face is ceramic coated as well as the entire exhaust valve and exhaust runner and the intake runners have been cleaned up and polished
    96 GQ coil/Cab
    08 G6eT
  2. The Following 11 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (20th September 2015), Bloodyaussie (20th September 2015), Cuppa (20th September 2015), GUtsy ute (4th October 2015), jack (21st September 2015), NissanGQ4.2 (20th September 2015), Onkey (5th October 2015), Punderhead (5th October 2015), Rossco (20th September 2015), Wine_maker (15th May 2018), Woof (20th September 2015)
    465 Post(s)
    Wow just a little bit of work into it Ben. Lol.
    Im assuming your hunting for the magic 200plus figures?
    Awesome!!!!
    Cant wait to go for a spin in this thing.
    22 Post(s)
    Dunno, the end power figure is going to determined by how much torque it produces, so it may very well stay at 180ish rwkw like is was before.
    Once the clutch wears out and I get a fully hectic one. I will really screw some fat into it for a brag run
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    mudski (20th September 2015)
  8. #5
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    well done mate. looking forward to seeing what you think of it.
  9. #6
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Very nice, Ben!
    John
  10. #7
    Thomastown, Melbourne
    6 Post(s)
    You live in the wrong state Benny
  11. #8
    Can't wait to see this!!
  12. #9
    22 Post(s)
    Maybe next year, between the fire season and snow season
    96 GQ coil/Cab
    08 G6eT
  13. The Following 4 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (21st September 2015), Bloodyaussie (20th September 2015), Rossco (20th September 2015), Winnie (20th September 2015)
  14. #10
    583 Post(s)
    Well done Benny, are you considering the Borg Warner now or stick with the garret?
    Edit: Just read your post again...lol....no worries!
