Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Redoing my BBQ area.
    My 6 burner jackaroo BBQ is getting close to the end of its life after 16 years. I want to strip it down and rebuild it to run on natural gas and lose the trolley frame and have it inbuilt. I will also run hot/cold water, sink, fridge and some bench area.
    Has anyone converted or have s natural gas BBQ. Pros and cons please.
    Will post updates with pics as it progresses along. If people want me to.
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I know plenty that have gone to natural gas BBQs and they love it. Just need to drill the jets a bit wider
    Lucus30's 1999 GU ST TB45E
    Quote Originally Posted by lucus30 View Post
    I won't be drilling anything.
    I need to change all the burners anyway and there's kit out there. I think there's a place in Thomastown that I pop in to.
    Advanced dave97's Avatar
    Jan 2015
    You might need new plates to they run a bit hotter from my experience.
  6. The Following User Says Thank You to dave97 For This Useful Post:
    jay see (17th December 2015)
    Go to a BBQ place and buy natural gas burners they will have the mixer with them.
    Agree don't go drilling anything, its a very volatile gas.
    when running you don't want to see yellow in the flame a strong blue to light blue is what you need.
    If you want some cast iron plates I have plenty here
  8. The Following User Says Thank You to threedogs For This Useful Post:
    Family4x4 (12th September 2015)
  9. #6
    Thanks for the offer mate, but that's part of the reason for fixing it. The cast ones that are on ATM are farked.
  10. #7
    You could go to an engineering shop and get a sheet of 12mm cut 600mm x 900mm.
    Or price up a piece of 6mm stainless
  11. #8
    Patrol God Stropp's Avatar
    31 Post(s)
    natural gas does not burn as hot as lpg so hence the need for bigger holes in the jets, get the jets changes and a new hose and then you may need to adjust the screw on the bottom of the burner (generally) to get the right burn. as for the plate just get a sheet of stainless cut or if you wish just buy a heatlie inbiult bbq and you will never have to replace it again, expensive but they are without doubt the best one around and aussie made too not cheap junk.
  12. The Following 3 Users Say Thank You to Stropp For This Useful Post:
    Bigcol (3rd December 2015), jay see (17th December 2015), threedogs (12th September 2015)
  13. #9
    Jul 2015
    Camden NSW
    6 Post(s)
    If you running it from your home's gas system you may need to change the jets in the regulator depending on he size of the incoming service supply. I had to as all my appliances are gas. If I had the BBQ on and someone was in the shower, the gas cook-top in the kitchen had very little gas. Changing the regulator jets fixed the problem.
    Yours may be OK.
    Bazza.
  14. The Following User Says Thank You to bazzaboy For This Useful Post:
  15. #10
    Every time I see a s/s plate they are don't look very clean...
    Are they harder to keep clean.
    Quote Originally Posted by bazzaboy View Post
    Yours may be OK.
    Bazza.
    Another thing to ask the Plumber. Thanks.
    Haven't had a chance to look into getting a new BBQ or redo my existing one yet, but have changed the clear roof sheets to white. Heaps better. No more moving chairs to follow the shade.
    Also installed a led floodlight above the BBQ so no more casting a shadow.
    Getting ready for summer......
