11th September 2015, 12:12 AM
#11
I am he, fear me
MEGOMONSTER
But it doesn't tell you that some 40 channel model channels don't work on the 80 channel models.
Like channel 22.
That isn't just to do solely with 80's either.
There are quite a number of 40 sets that won't tx on 22 either
Transmission on Channel 22 on later model 40's and most 80's built by the better manuf's released into Oz is inhibited as a factory setting as it is an illegal freq for voice on the ACMA freq spectrum.
The Following User Says Thank You to the evil twin For This Useful Post:
MEGOMONSTER (11th September 2015)
11th September 2015 12:12 AM
11th September 2015, 03:40 AM
#12
it's because of the older 40 channel sets running wide band and the new 80 channels sets running narrow band. . . . you can hear the older ones on new sets if you turn your volume right up if that helps?
Wetty.
The Following User Says Thank You to Wetty For This Useful Post:
11th September 2015, 07:29 AM
#13
I've asked this question a long time ago but may as well have another crack: I have an 80 channel, brought it brand new with a 3 dB aerial. All my mates have 40 channel and I'm lucky to catch half a word or anything at all more than fuzz. Even if I'm 5 metres away from the car that's transmitting. Could it be an 80 vs 40 problem?
tappin from tassie
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
11th September 2015, 09:35 AM
#14
Dribble Master
taslucas
tappin from tassie
Maybe, maybe not
11th September 2015, 10:15 AM
#15
Cheers, now I know where I'm at! Haha
tappin from tassie
11th September 2015, 01:35 PM
#16
I am he, fear me
taslucas
tappin from tassie
Probably not, unless, you bought an el cheapo set then Clunk may be right ;-).....
A good quality 40 communicating with a good quality 80 neither station should have any issues at all
In a group/convoy or whatever the 40 sets may be a discernably lower volume than 80's on an 80 receivers.
That will vary from vehicle to vehicle as it depends on the individual receiver tunings
Can your mates hear you OK with no interference, good clarity, etc if you transmit?
Is the received volume OK but the voice modulation up to poo IE is their signal loud but unreadable or do you have to crank the vol up to max?
Can you clearly hear transmissions from some/most other stations OK IE truckies etc?
Can you find someone with an 80 handheld or even try a call for a "radio check from any other station using an 80" out on the Hwy?
Bottom line, if it is "everybody" then the issue is probably your antenna cable run/connectors but if it is only 40's then the issue is probably in the deviation settings on the set itself
11th September 2015, 02:46 PM
#17
Moderator
I can't believe Clunk started a thread that has such a productive and valuable contribution.....
You've changed Adrian!! It's the Pub Thread isn't it?
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
Clunk (11th September 2015), taslucas (11th September 2015), Woof (11th September 2015)
11th September 2015, 02:58 PM
#18
Dribble Master
MudRunnerTD
Don't worry mate, I won't be making a habit of it
11th September 2015, 04:31 PM
#19
the evil twin
Others can't hear me.
The volume is fine but transmission is all fuzz.
The unit is a good quality uniden but the aerial was a cheapy with its cable hard wired. I reckon I should just buy a decent aerial.
tappin from tassie
11th September 2015, 05:02 PM
#20
Dribble Master
taslucas
tappin from tassie
weren't you told that previously????
