Results 1 to 10 of 11
Thread: "Security" bolts? For light bars etc? Suggestions?
    Renmark SA
    Hey fellas,
    I keep seeing lightbars getting knocked off, and was wondering what you mob use as security bolts.
    Mark
    NT blood in QLD mud.
    I dont know nuthin' about no stolen generator.....
    I have drilled the bolt and used a castle nut and split pin.
    You can buy security bolts, allen heads with the pin in the centre
    Mind you the allen key costs a small fortune
    Quote Originally Posted by no eye deer View Post
    Hey fellas,
    Mark
    Unless you spend about $40 bucks on the fasteners nothing much works against a full on thief but tamperproofs deter the opportunistic ones that only have a shifter or a multi tool
    $20 (or free to shop lifters) gets you a set of drivers for almost every common security bolt in use, tri-wing, security torx, security allen etc
    http://www.jaycar.com.au/Tools-%26-S...t-Set/p/TD2038
    330 Post(s)
    I use Lightforce security nuts on the spotties and the light bar is on the roof so a pain to steal. The Lightforce ones are good but someone with a pin driver and hammer will remove them with some effort and noise.
    330 Post(s)
    $40 for a pair on eBay
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Bigcol (14th August 2015)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I have them as well...........
    wont stop someone with time and patience, but will stop little sods thinking they can get away with it
    I lost my reversing spots off the back of my car a few years ago, they are now double nuts with locktite 406 and something else..........
  9. #7
    Advanced dave97's Avatar
    Jan 2015
    You could mount a truck battery in the back for sole purpose of making your nuts and bolts live, would deter people from trying again
    Or put a extension cord that you can hide, plug in to 240v over night sometime touches it it's going to hurt and they won't do that again
  10. #8
    Maybe even drill a small hole in the end case of
    the light bar and use some loc wire as a deterrant
  11. #9
    80 Post(s)
    Quote Originally Posted by dave97 View Post
    Unfortunately setting a 'man trap'
    will result in a lengthy prison term.
    And accidentally killing your kids is a
    frowned on, just a little bit too.
  12. #10
    Jan 2015
    Only set it when going to bed and make friends with a pig farmer problem solvered lol
