15th August 2015, 01:32 PM
PEDAL throttle position sensor issue zd30
hi guys
2005 gu4 zd30
I think i got the problem of faulty TPS . Once in a while the pedal would be non-responsive ( not revving ) . a few seconds later it works. I'm going to try and take it out and drill and clean as recommended on the forum. If all fails
Could i replace with one like this http://www.ebay.com.au/itm/GENUINE-N...item1c4352a573
Do i need to do any adjusments or reset when i take out the tps and put it back ? or straight fit in ?
Let me know any other recommendations regarding removal, cleaning etc..
thanks heaps
Limmy
15th August 2015 01:32 PM
15th August 2015, 01:46 PM
Hey mate.
Nissan recalled the pedals/TPS on some VIN ranges. Yours is out of date range, but I know for a fact some 2005 are affected, as my workmates early 2005 was done free of charge by nissan. Might pay to get in touch with Nissan and find out ?
https://www.recalls.gov.au/content/i...itemId/1051841
15th August 2015, 01:49 PM
unfortunately i just missed out with my vin
15th August 2015, 03:35 PM
I heard some of the Members from OS remove the TPS and drill {carefully]
a small hole in it and squirt with CRC or similar with good results, di for new learningsconnect the battery
while you do this as well, resets the ECU
Give Mudski a PM he may stock TPS's
15th August 2015, 10:22 PM
i might try and crack it open.
If i get a new unit. Do i need to adjust ? or straight replacement ?
16th August 2015, 12:52 AM
Just remove and refit.
6th September 2015, 06:38 PM
hi guys
i bought a brand new replacement and changed it over. still same problems. $(KGrHqFHJEgE92!f41LtBPh(6LSldw--60_12.JPG
I also noticed there a little BOSCH sensor on the bottom of the pedal ? what does that do ?
any other ideas ?
6th September 2015, 08:27 PM
How's the serenity
Is it overboosting ? hitting limp mode ?
The price of excellence is dicipline , the cost of mediocrity is dissapointment .
7th September 2015, 04:36 PM
boots
when im in gear and press the pedal down nothing happens. then i try step on a few more times. then it works normally
i think its to do with pedal
im out of ideas now
7th September 2015, 09:15 PM
How's the serenity
You have not answered the question. What is your boost pressure ? Your symptoms could be related to something else.
