Page 535 of 1053 FirstFirst ... 354354855255335345355365375455856351035 ... LastLast
Results 5,341 to 5,350 of 10524
  1. #5341
    Patrol God Stropp's Avatar
    31 Post(s)
    Well he wont be surprised now will he? Lol
    Yes he will, he can't read and he's up north, maybe back today
    Yes he will, he can't read a do he's up north, maybe back today
    Well hes been on facebook, so Im guessing being up north hasnt stopped him lol
  4. #5343
    31 Post(s)
    Nah I told you he can't read, he just fools everyone, ebony has to read it to him lol
  5. The Following User Says Thank You to Stropp For This Useful Post:
    Woof (25th July 2015)
  6. #5344
    Hahahahaha you're a mean bastard
  7. The Following User Says Thank You to Clunk For This Useful Post:
    Stropp (25th July 2015)
  8. #5345
    Changed the glow plugs, very painfull but got it done. easy enough
    Tips broken off two the other two were worn down, 220k on the clock first set
    middle one is the new one
    Can someone tell me if I should of removed the butterfly
    from the throttle body or whatever its called???
  9. #5346
    Quote Originally Posted by Bloggsy View Post
    Hey Mudski, What do they say? Oils ain't oils -LOL!! Same goes for tyres I reckon. Even tough I have not actually measured them, you can see they are a larger diameter than the BFG's even though they are both 285/75/16. My BFG's still had about 9-10mm of tread before I changed over to the hankooks, so not overly worn down. I also have the hankooks in 315/75/16 and when parked next to a mate of mines Patrol wearing the same size tyre, 315/75/16's but in BFG KM2's you can quite clearly see that the hankooks are larger. I'm not saying there's a huge difference but it is definitely noticeable. Oh and I do understand that a 285/75/16 is closer to a 32.5" but we generally refer to them as 33's. Actually come to think of it, before I had the BFG's I had MT MTZ's in 285's and I remember thinking then that the BFG's looked smaller than the MTZ's they just replaced.
    The Hankooks are pretty quiet on the road, comparable to the BFG's when new. What they are like after they've worn down a bit is yet to be seen... Or should that be heard? Pretty sure Stropp has clocked up more K's on his Hankooks than I have on mine which is just under 5000k's. I've found them pretty good on the blacktop in the rain too lately, considering they have no siping. I have to admit that the BFG's are a little better in the mud though.
    Each manufacturer has different sizes, actually a 285 is the same diameter as the old 7.50 x 16 which is a 33"
    Look at each tyres specs and see how many millimeters in one rotation. To say a 285 is a 32.5 is not correct,
    some say its 33.2 so again look at the specs, some have a larger rolling diameter than others.
    My 33x12.5 x15 Mongrels were in fact a 34' x 13", so you never can tell,
  10. #5347
    465 Post(s)
    Dont bother John. Just take the vac hose off the actuator for the swirl valve if you want. It stays open when the engine is off. Just block the hose if you take it off.
  11. #5348
    465 Post(s)
    Ok you have successfully confused me... lol.
  12. #5349
    43 Post(s)
    Made a start.
    Made a start.
    What ya doin now?
