Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: ZD30 Di replace with new or reconditioned?
  1. #31
    As a matter of interest,
    does anyone know if
    it is possible to source
    the newer CRD block
    and fit the DI head and
    other components?
    175 Post(s)
    I don't see why not mudnut. As it is a newer engine meeting new emission rules. You'd have to bring over a few things from the CRD donor. Like ECU,intercooler... I'm sure theres a few more things.
    mudnut (8th July 2015)
  5. #33
    Sorry for the hijack.
    Pardon my ignorance,
    but why, would you need
    the ECU if you used the
    DI engine control?
  6. #34
    175 Post(s)
    DI engine control?
    Well the ECU controls other functions. For example the boost through the vaccum solenoid. It also controls the aircon clutch, disengages it when engine is over certain temperature or under certain load.
    On a CRD it controls much more. Controls the injection pump, EGR valve, etc...
    Someone correct me if I'm wrong here, but without ECU these grenades cannot function.
    Mar 2013
    NE Melbourne
    If only using the crd block but the Di head then old ecu is needed. If planning to run as crd then new ecu is needed. But I an not entirely sure if both blocks are 100% compatible.
  8. The Following 2 Users Say Thank You to Rock Trol For This Useful Post:
    Hodge (8th July 2015), mudnut (8th July 2015)
  9. #36
    So if Mr Nissan is still
    making the CRD block,
    then it would probably
    be the best way to go
    if you aren't keen on
    acquiring a reco DI
    wouldn't it? Has it
    been done before?
  10. #37
    175 Post(s)
    I reckon it would cost an astronomical fortune to buy a new block / engine from Nissan. I haven't priced one up or heard about ones pricing but, if general pricing from nissan parts is anything to go by, well I'd love to see this figure.
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #38
    175 Post(s)
    Quote Originally Posted by Rock Trol View Post
    The CRD block has a completely different IP bracket / assembly. The VP44 would not fit on a CRD block, by looking and comparing them in the manual. Vp44 is much more complex.
  13. The Following User Says Thank You to Hodge For This Useful Post:
  14. #39
    Mar 2013
    NE Melbourne
    Good pick up Hodge. Looks like rebuilding the old block I the only way to go. If its a really old engine then maybe getting a late model Di block from the wreckers is the go. It would have updated internals such as oil system.
  15. The Following User Says Thank You to Rock Trol For This Useful Post:
  16. #40
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Jono6974. I will probably regret typing this as I am about to do a Simpson desert crossing but mine has just clicked over 200k and still going strong. I fitted the catch can, boost limiter (dawes value) and boost gauge at 140k or so, and have recently 198k fitted a secondary fuel filter and lift pump.
    One word of advice get your intercooler off and clean it out if you haven't (decreased or unleaded petrol, making sure to rinse and dry thoroughly before refitting). Also check/clean the intake (butterfly) vent just after it. You will be surprised how dirty it is from the egr.
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
