Results 31 to 38 of 38
Thread: Mudski's massive ZD30 part out.
  1. #31
    Jan 2015
    Hi Mark
    Will the alternator and tensioner fit a 2012 CRD
    If so I'll take them as spares
    Norm
    465 Post(s)
    Hey Norm. The tensioner technically no. The pulley wheel size is the only difference. Yours is smaller. The shocker is the same though. And the one on this is brand new OEM and they are over $100 for the shocker alone. I only just fitted it on and threw it under the seat as a spare. As for the alternator, I'm not sure. I'll do same digging around later and see if you like.
    Cheers.
    Mark.
  4. #33
    Jan 2015
    If it's only the wheel that's different I could just carry a bearing for
    mine and replace it if things do go pear shaped.If you could look into
    the alternator I'd appreciate it or let me know what year ect. and I'll
    try from this end. As I said they're only spares
    465 Post(s)
    I haven't looked yet mate. The bearing I think is the same in the pulley, think. The only difference is the OD of the wheel. As for the alternator, is off a GUII 2001 ZD30.
    Edit : I just typred in ZD30 Alternator into eBay and the first search reveals from 2000-2013 are the same.
    http://www.ebay.com.au/itm/NEW-ALTERNATOR-TO-FIT-NISSAN-PATROL-GU-3-0L-TURBO-DIESEL-ZD30DDTi-2000-TO-2014-/290956901215?pt=LH_DefaultDomain_15&hash=item43be6 1fb5f
    Quote Originally Posted by Getaboutabit View Post
    I just checked my catalogue for the tensioner and it states the shocker is the same. Only the pulley wheel sizing. So I assume we are right on that.
  6. #35
    Jan 2015
    Sounds like a deal.
    How do you want me to organize payment.
    I'll do it straight away.
  7. #36
    465 Post(s)
    Sounds like a deal.
    PM on the way....
  8. #37
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Hi mark.. cheers for the hose to try out.. also if the ecu talk is stil available i can transfer money over wed... will send u a pm once ive sent payment... aw and hopefully finally sorted out the high idle issue... was the tps sensor... since fitting another sensor/pedal asembly havnt been able to get it to idle high and everything seems to per working per normal...
    Sent from my SM-N915G using Tapatalk
  9. The Following User Says Thank You to mullet_hunter For This Useful Post:
    mudski (6th July 2015)
  10. #38
    465 Post(s)
    Quote Originally Posted by mullet_hunter View Post
    Too easy mate.
