1st July 2015, 02:39 AM
Driving on front wheels only
Hey guys,
I've been wondering...............
In case of a drama like the rear diff blows up, is it possible to drive on front wheels only for some decent distance??!!
If so, how long do you think a GQ patrol can be driven that way and how fast can we safely go?
I'm speculating on a temporary solution like disconnecting the rear drive shaft, letting the rear wheels turn without
the drive train.
I'm not too sure whether it's possible when blown diff is the cause of it(or blown pinion bearing, etc rather).
I know the pinion gear and ring gear failure is rare in Patrols. It would most likely a bearing failure.
Since there's no hub connect/disconnect arrangement in rear, when the wheels turn, the axle and the diff would
turn as well.
So, perhaps the diff would keep turning like it's coasting, with minimal noise, unlike when the drive
shaft is connected to the damaged or worn diff???!!
Any ideas?
1st July 2015 02:39 AM
1st July 2015, 07:07 AM
It's possible to drive on front wheels only if necessary, however there are not many instances where this would be beneficial in a Patrol i would reckon. The main reason to do this in my opinion would be to isolate the tail shaft if there was a problem and take it out. If rear diff has issues it will still be spinning, i know with no load but still have potential to go bang or lock up. Wheel bearings can't be isolated and axles can't be removed like full floating type in yotas. Driving in 4wd carefully might be an option to help take load off. Depend on the situation i guess. Bent or broken lower control arm this will help or potentialy a situation to concider to drive with front wheels only carefully to get out of the poo.
1st July 2015, 12:05 PM
Many years back a mate with a Perado (thanks Jase) blew a rear diff in the bush. We pulled the diff out and removed the crown wheel (it was just about toothless), reassembled and he drove home on the front wheels, about 150ks.
1st July 2015, 01:33 PM
Also many years ago, we were camped on Double Island beach when this young couple walked in to camp about 7pm in the rain. They were on their honeymoon.
He was a mechanic and as usual his own car was the last one to be worked on. The unis on rear tail shaft had seized so no way to get back to Noosa.
We gave them a feed and a couple of drinks and when the rain stopped and with a bit of help and borrowed tools from us drunken idiots, he dropped tail shaft and drove down the beach in front wheel drive to return next morning with a carton of XXXX.
I think it was a Jeep but not sure.
I bet they still remember that trip.
1st July 2015, 02:21 PM
Thanks for the posts guys.
So far from what I understood, I reckon it is possible with a GQ with some caution.
The biggest problem with GQ is the axle is a semi floating one.
Which means the axle can't be removed without the aid of a hydraulic press.
I've been having enough trouble trying to remove the bearing nut which I couldn't get it off even with
heavy banging with a drift.(some 350Nm torque on it, but I reckon way more than that in my one).
So, unless there's a clever backyard method to get the bearing off the axle, I reckon the only solution
is to cut the axle with a hacksaw or a grinder. But if the problem with the diff doesn't cause it to lock,
then there's a good chance driving for a decent distance by removing the rear drive shaft.
Am I right about that?
Another solution would be to pull the diff centre out and remove the crown wheel as TimE mentioned above.
That's also possible with a Patrol, is it not?
That's probably the least damaging solution in such a situation.
Yes, there's no doubt the right tools are necessary. But, most of us carry some tools in the back of the fourby anyway.
The above mechanic fella who was in his honeymoon was an exception(or may be not, he was in a too happy mood to
carry any tools with him I reckon) ![Big Grin](images/smilies/biggrin.png)
Thanx
1st July 2015, 02:48 PM
dom14
Thanx
I think he was only concerned about using one tool that weekend. Lol
Live life, Love life.
Snatch straps on towballs can harm and/or kill!!!!!!
1st July 2015, 07:44 PM
krbrooking
Yep, obviously too excited to remember even that one tool might need backup tools from the tool box to get going.
He wasn't the only one who's too euphoric to remember the value of the backup tools though.
I'm sure we all done that.
1st July 2015, 08:07 PM
dom14
Thanx
GQ or GU or anything else, you can't remove diff centre unless you remove axle shafts first! So for semi floating hubs this is not on the side of the road fix in the hurry and you have to refit them back in after the diff centre is removed in order to be able to refit and roll on the wheels. I'll rather pay for the tow truck or shred the diff instead than do this on the side of the road or in the middle of desert.
If you have full floating hubs than it is much easier, if you want the diff not to spin just pull the axle shafts out (or just one if open diff) plug the holes with rag or tape them and disconnect rear prop shaft and drive with front drive only as long as you like.
1st July 2015, 08:51 PM
Yeah, but paying for a tow truck may not be a luxury in the middle of the desert or far out nowhere.
So I think the time spent on pulling out both axles and then pulling out the diff centre and removing the crown wheel
is well spent.
Full floating axle is not a luxury in Patrols(at least in GQ).
I wonder why Nissan decided to do it that way.
Semi floating axles are PITA IMO. Very hard to replace the bearing without special tools,
let alone removing the axles in an emergency situation like above.
So, removing the crown wheel sound like a good solution to prevent the diff from getting locked from existing damage.
So, if I understood correctly,
Assuming calling for roadside assistance is out of question in a particular situation,
For a GQ Patrol,
Removing the diff centre and then removing the crown wheel and then driving on front wheels is a valid solution to get
the vehicle to somewhere where you can get the diff fixed.
1st July 2015, 09:28 PM
dom14
I'll rather have it skull dragged out to nearest tow truck pick up...
is well spent.
Have you ever done such thing as removing diff centre? I think you'd reconsider the "time well spent" especially in the middle of the desert, its bad enough job in the workshop ....
Unless you are at CSR, spending 2 days removing and refitting the rear diff centre with countless opportunities for stuff ups or fails
Full floating axle is not a luxury in Patrols(at least in GQ).I wonder why Nissan decided to do it that way.
Its cheaper and not really needed for the GVM loads.... leaf sprung GUs with H260 have full floating hubs.
Well, there you are, answering your own question.
For a GQ Patrol,
Only if you are really really desperate and out of all options.....I'm a pro and honestly I'd have refused to be that desperate, rather yank the fuel hose off and strike a match.........
I like my Patrol but it is not worth that much pain....
In any case this scenario is almost impossible on Patrol GQ or GU alike, it only applies to Swiss cheese diffs from Toyota and their owners are known to be desperate
so is it really GQ you are concerned about?
B/R
The Following User Says Thank You to Rumcajs For This Useful Post:
