Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Show me your tablet holder
    193 Post(s)
    Yeah bugger... out of my price range.. i still owe some nob cash for parts ....lol
    Might make my own ??
    Yeah I'm just thinking of making something up and adapting it to the cheapie I've got. Just make a bracket that will work with the jesus bar or screw into the dash (maybe) and screw into the cradle part. . . Get rid of the suction cap which reduces vision anyway. . . On my long list of things to do . . .
  2. The Following User Says Thank You to Rossco For This Useful Post:
    Bloodyaussie (17th June 2015)
    I see ram make a pipe clamp attachment which you would replace the suction cup with. You could clamp it around the Jesus bar.
  5. The Following User Says Thank You to Winnie For This Useful Post:
    Rossco (17th June 2015)
  6. #23
    Patrol Guru Rocket55's Avatar
    Sydney
    Quote Originally Posted by Malgreen View Post
    Well done Rocket55..
    you beat me to it, i got plans on doing the same thing,,
    that is a perfect place for it..
    all you need now is a USB socket next to the ball so you dont have wires running every where... that was my plan to do..
    just one question for you.. what was the length of the arm???
    Hi Mal, I took those pics a while ago and have since mounted a dual Narva USB plug on the left hand side of the pocket so it keeps all the wires in check. It works a treat. Here is the parts list I used.
    I've also put a small piece of felt on the bottom side of the arm where it rest on the front edge of the pocket as it was starting to leave a tiny mark. No issues now. I've been off road many times with this from mild to relatively wild and driven all over the VIC HIgh Country and it doesn't move, vibrate or carry on. It just sits there as if it was a permanent fixture.
  7. The Following User Says Thank You to Rocket55 For This Useful Post:
    Malgreen (17th June 2015)
  8. #24
    Patrol Guru TimE's Avatar
    Canberra
    Check my write up of a RAM Mount with bigger balls (1.5") here. Didn't require pulling the dash apart. The set up has been tested over 15,000k of tough tracks, vibrates a bit on corrugations, else works well.
  9. #25
    Patrol God Stropp's Avatar
    31 Post(s)
    Quote Originally Posted by TimE View Post
    That's exactly how mine is except I put the locking wing nut down so it touches the base of the glove box so it doesn't bounce at all.
  10. #26
    Expert ozjeff's Avatar
    Apr 2013
    North Gold Coast, QLD
    Just looking for new mounting options as my last one basically has melted on the windscreen and Ram Mount seems to be the one to use.
    Those with the older GU dash, are you using the long double clamp to get it closer to you?. My present one is around 220mm from windscreen to basically edge of the dash. This way I can actually press it almost without taking my hands off the steering wheel.
    Current holder (eBay):
  11. #27
    Quote Originally Posted by ozjeff View Post
    Down here thats illegal mounting it on the centre of the Dash. still has me beat why you want/need these things.
    Just look at a map, PPL are relying too much on electronics.
    We made it to Cape York in 83 with just paper maps via the creb track.
    and made it to Birdsville using the same , makes me laugh when I see stuff like this.
    It it legal to even have them.................... I've seen the guys on All 4 adventure use there tablet
    but its not bolted to the dash PML
  12. #28
    Who says its illegal....... and why carry a shed load of maps when they can all be stored on the one device
  13. #29
    to me its over complcating navigation. Surely as an eg you can get to Broome without a tablet to look at lol
    waste of space,,,,,, wonder what would of happen to Billy if he had a tablet bracket sticking out of his dash.
    Not a fan sorry
    Any mod really needs a cert as you should know ,
  14. #30
    Thomastown, Melbourne
    6 Post(s)
    Not asking for opinions ..... I just wanted pics of others ... mainly GQ's.
    Not having another argument with an oldie about the good ol days and my Tom Tom is all I need.... each to there own.
  15. The Following 4 Users Say Thank You to Bloodyaussie For This Useful Post:
    Clunk (22nd June 2015), lucus30 (22nd June 2015), Throbbinhood (22nd June 2015), Winnie (22nd June 2015)
