4th April 2011, 12:12 PM
Administrator
The Following 40 Users Say Thank You to AB For This Useful Post:
@GUte (1st October 2013), AussieRoadHammer (5th May 2011), Ben-e-boy (4th April 2011), Bidja (29th January 2019), big_fletch (16th May 2011), Bob (4th April 2011), Bruza (13th May 2011), brw1994 (8th January 2013), canuck (15th December 2011), Dhuck (4th April 2011), Finly Owner (4th April 2011), FNqGu04 (15th January 2017), Goldifox (18th November 2013), GUtsy ute (10th April 2011), janderson (16th September 2013), JoeG (17th May 2011), Kast (9th August 2013), Majestic (23rd October 2014), Maxhead (4th April 2011), mjr350 (30th April 2015), Muttley (29th July 2013), my third 256 (5th April 2011), NissanGQ4.2 (4th April 2011), NotTortoise (9th November 2015), oxmann (21st November 2012), Parksy (7th August 2014), patch697 (4th April 2011), Plasnart (4th April 2011), Rip'n'Shred (15th March 2012), ripper (16th May 2011), Robo (3rd March 2012), RustyR (14th September 2011), sibbles (6th January 2012), Sir Roofy (4th April 2011), Snafu (18th January 2012), Tank (9th June 2012), taslucas (17th December 2011), the ferret (4th April 2011), twisty (15th November 2011), wannabeturboed (6th October 2014)
4th April 2011 12:12 PM
4th April 2011, 12:22 PM
These thing leave a nice finish & I could go spastic with a box of them.....lolol
Thanks AB bloody good post.
4th April 2011, 12:25 PM
Administrator
Forgot to mention...
On the outside of the nutsert there are grooves which are suppose to bite into the metal and to stop it from spinning.
Sometimes the nutsert can spin when you are trying to do the nut up on the bolt which makes me angry...lol
If this happens then you need to stop it from spinning whilst you do the nut up so try doing the following.
- Hold the bolt on an angle to try and force it to lock in to the side of the panel
- Take the nustert and bolt out....Hold the bottom edge of the nutsert with visegrips and do a few rotations to expand the nutsert a little bit and try again...This will make the nutsert a wee bit bigger and should bite in better....You may have to hammer the nutsert back into the hole again too.
The Following 4 Users Say Thank You to AB For This Useful Post:
Bidja (29th January 2019), Parksy (7th August 2014), ripper (16th May 2011), the ferret (4th April 2011)
4th April 2011, 12:30 PM
AB
You might also try using 2 washers with a dab of grease in between them to give it a slip point.......... Don't know if it would work but worth a try.
The Following 2 Users Say Thank You to patch697 For This Useful Post:
AB (4th April 2011), Finly Owner (4th April 2011)
4th April 2011, 07:24 PM
Administrator
patch697
Yes mate that would work on ensuring the bolt can pull up but I was referring to the actual nutsert spinning inside the substrate you are trying to lock it in to.
They sometimes spin whilst your are trying to force the bolt up when spinning the nut so you may have to reef the bolt to one side or take it out and expand it a bit and ram it back in to the hole and start again.
4th April 2011, 07:26 PM
SUCH IS LIFE
Wow...what a neat little beauty.
Thanks for sharing mate
________________________
______ 2017 D-Max _______
4th April 2011, 07:42 PM
and are these nutserts at the local hardware or bunnings ?
4th April 2011, 07:53 PM
#8
Administrator
roofy
No Bunnings will not supply them...I highly doubht it anyway.
I would be going to a proper nuts and bolts company, maybe Mitre 10 but doubht it also.
Ebay Roofy ----> http://shop.ebay.com.au/?_from=R40&_...All-Categories
The Following User Says Thank You to AB For This Useful Post:
MudRunnerTD (5th April 2011)
4th April 2011, 07:54 PM
#9
Administrator
Don't forget to get velcro, foam or some kind of padding between the car and the bracket too.
4th April 2011, 08:07 PM
#10
AB
thanks mate will do
