I completed my first servicing on a Patrol yesterday afternoon!
I had a diesel Hilux 20 years ago and had a hell of a time changing the fuel filter on that. Even the NRMA guy couldnt start it afterwards. So that part of the servicing was nerve wracking for me haha.
60,000km
Air filter was straightforward
Oil filter was ok too. I used the instructions Rod gave me and it was relatively mess free. I didnt realise how much 8.2 litres looked like in my oil pan, and was lucky it didnt overflow. Note to self - buy a bigger oil pan.
This is the hose you use to drain oil from the little drain pan underneath the filter.
Looks due for a change (and no i didnt stick my hand in the oil lol)
Dont forget to put this little plastic piece into the replacement filter.
After hours of reading forum posts about which oil, I decided on Penrite Semi Synthetic HPR Diesel 5 5W-40. I really wanted a full synthetic but couldn't find one that was highly recommended and met the manufacturers specs. Mobil 1 came close but it doesn't look good in some of those oil test articles I read. I based my final decision after reading an article that I think Chaz wrote.. (which i cant seem to locate atm, but will link when I do). Will see how the Penrite goes. Happy to listen to any recommendations you guys might have too.
Last was the fuel filter.
Here are the instructions I used and after following this, I barely spilled a drop of Diesel and the engine fired up first go Below is my slightly modified version.
Fuel Filter
1. Remove the hose from the outlet side of the bulb and seal off to prevent dirt ingress and fuel spillage (this is the one toward the outside of the engine bay and goes to the filter). Disconnect this hose from the bulb end and leave the hose attached on the filter assy. Swap that hose to the new filter when it's removed for easier access.
a. Drain filter at side mounted drain port into a thin bottle, retighten drain. An old Windex bottle fits in there nicely. I couldn't get any fuel to run out, but I found out later that was because I didnt unscrew it enough. This step is redundant in any case if you're careful when removing the filter.
2. Disconnect remaining rubber hoses and seal off.
3. Remove filter mounting bracket by unscrewing 2x holding bolts.
4. Lift & rotate assembly to access bottom mounted sensor plug.
a. Carefully remove the wire retaining spring that holds the sensor plug in place.
b. Clean plug contacts.
5. Lift unit out & replace filters and swap out the hose from step 1.
6. Reposition unit to connect sensor plug.
7. Bolt mounting bracket in place.
8. Refit 2 off small return line rubber hoses.
9. Prime hand pump:-
a. Loosen fuel tank cap.
b. Squeeze hand pump bellows.
c. Block rubber hose outlet of pump with thumb.
d. Allow bellows to expand which will draw fuel from tank. e. Release thumb & squeeze pump bellows to check for fuel.
f. Repeat b,c,d until fuel appears
g. Connect this rubber hose to filter inlet.
For me, this only took 2 or 3 pumps by hand before fuel was flowing.
10. Prime filter:-
a. Squeeze hand pump bellows.
b. Block filter outlet with thumb.
c. Allow bellows to expand which will draw fuel from tank & push fuel through filter.
d. Release thumb & squeeze hand pump bellows to check for fuel.
e. Repeat a,b,c until fuel appears.
f. Connect fuel pump rubber hose to filter outlet.
11. Tighten all bolts and try an engine start.
12. If engine idles tighten fuel tank cap and go for a 10km spin to exorcize any more air.
I emptied the contents of the fuel filter into a container just to see what came out. Plenty of crap in there and no water.
Also emptied the Provent tube and found this sludge. Better than in my container than back in teh engine!!
Was first time emptying the Catchcan tube so not sure what to expect or how much, but was surprised to see water in there. Is that normal? Probably condensation, will keep an eye on it.
Lastly, I reset the ECU since it had new air filter, fuel filter, new exhaust etc. Not that the truck was running poorly, but I reckon this should help her run better
Here's the ECU reset procedure I used. Not sure if it's right, or whether it worked.. but I did have to re-enter the radio security code etc.
Reset ECU
1. Note your radio code and odo readings
2. Remove positive terminals from all batteries.
3. Step on brakes for 10 secs. Leave car to sit for 15 mins.
4. Refit battery terminals
One other thing, I have Scan Gauge II permanently fitted. It wouldn't turn on after the ECU reset for some reason. I fixed it by disconnecting it from the OBDI plug, starting the car, turning it off, reconnecting, and then letting it do its communication link setup again.
