Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: First trip
    Sep 2014
    Scone NSW
    Original came with 265 I'm running 275s currently with no lift
  2. The Following User Says Thank You to toad_au For This Useful Post:
    threedogs (1st May 2015)
  3. #12
    you're getting good miles from your Patrol thats for sure
  4. The Following User Says Thank You to threedogs For This Useful Post:
    toad_au (1st May 2015)
  5. #13
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Quote Originally Posted by toad_au View Post
    :-) pic of a crossing
    Nice PIC looks like a good little crossing
    Lucus30's 1999 GU ST TB45E
  6. #14
    Sep 2014
    Scone NSW
    Yeah its going well I had to replace the injectors due to 2 leaky ones but it's going well had my first sliced tire last month was a fresh grated road will definitely lower pressures now was a costly exercise
  7. #15
    Even if you only lower to 30 psi it helps,
    at least you can drive on hwy if you forget your compressor
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #16
    Sep 2014
    Scone NSW
    Thanks for the tip I'll remember that!
