I dont have funds for multiple Dyno runs, wish I did.
I will also be changing the rear IC pipe which I think is less than 55mm
and enlarges to 60mm, more air in plus Ill be using gold tape on some pipes to try to keep the heat down.
FYI my DP chip is set on 5 atm, max boost is about 20psi, we will see eh.
