Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Buying A 2011 GU with 120,000km - what to look out for
    Expert skiman's Avatar
    Apr 2015
    Fern Bay NSW
    Hey guys
    I'm looking at buying my first patrol. Request some advice about what I should be looking out for with a turbo diesel at this age.
    Got any tips or advice that might prevent an unwanted surprise in my shed in a couple weeks? Would appreciate any insights before I send the nrma mobile bloke over to do his inspection.
    Cheers!
    .......... TPC's Avatar
    63 Post(s)
    I think like with any vehicle but more so with these is service records to show it has been regularly serviced.
    Regular servicing
    Fuel Pump Leaks
    Intercooler Leaks
    Coolant Leaks
    Manifold Gasket Leaks (thanks Kev)
    Swivel Hub Leaks
    Oil weep from drivers side front of block
    80 KPH death wobble
    2011 and 120 K sounds like an ex-Lease Vehicle to me
    X 2 on the coolant leak, hard to spot as well, look underneath for signs of off road use.
    An oily intercooler will mean its leaking, but warranty should cover that .
    History,,,, history,,,,, history, make sure your book is stamped and check
    what has been changed under any recalls
    63 Post(s)
    Regular servicing
    Fuel Pump Leaks
    Intercooler Leaks
    Coolant Leaks
    Swivel Hub Leaks
    80 KPH death wobble
    Just curious, what is the 80 KPH death wobble?
    Patrol Freak kevin07's Avatar
    georges hall
    Regular servicing
    Fuel Pump Leaks
    Intercooler Leaks
    Coolant Leaks
    Swivel Hub Leaks
    80 KPH death wobble
    manifold gasket and find out who the previous owner was it will be in the log book also check the servicing and actually who has been servicing it if it doesnt have this move on to the next one
    13 y62 the beast that burbles
    Steering vibrations at 80 KPH...
    63 Post(s)
    What is the common cause?
  10. #9
    a number of fixes but most believe its a bushes issue
    and only use OE bushes
  11. #10
    Tyres
    Rims
    Swivel Hub Bearings
    Wheel Bearings
    Castor
    Panhard Bushes
    Control Arm Bushes
    Steering Damper
    Lifts
    Bent diff
    Ball Joints
    etc
    etc
    http://www.nissanpatrol.com.au/forum...archid=5292389
