Results 21 to 30 of 32
Thread: My Dual Battery Install
  1. #21
    Expert clubbyr8's Avatar
    Penrith, NSW
    3 Post(s)
    Quote Originally Posted by megatexture View Post
    That stuff looks like standard auto split tube you can get it cheap at sca or repco or possibly even ebay
    Thanks mate........
    GROOVY GUVII
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Volt gauge. Got it off ebay: http://www.ebay.com.au/itm/371056364...84.m1423.l2649
    Available in Red Green & Blue. (check the measurements on their page, does a couple of different sizes)
    Cut out Measurements: Length 30mm x Width 21mm
    Actual size: Length 34mm x Width 24 mm x Depth 17.5mm
    (edit: The conduit is the split type, from a Jaycar Store.)
    Was a CRD
  4. The Following User Says Thank You to ova50 For This Useful Post:
    clubbyr8 (16th May 2014)
  5. #23
    43 Post(s)
    Quote Originally Posted by ova50 View Post
    If anyone wants one I have a brand new one surplus to my needs. Red numbers
    Pay postage and it's yours.
    Penrith, NSW
    3 Post(s)
    I already ordered the voltmeter before your post and it turned up today, it's slightly bigger than your one (cutout is 45mm x 25mm), so I can't use the blanking plate and I had to file the hole slightly larger, I was hoping to mount my on-off-on rocker switch there, but not enough room and I have a small gap underneath the gauge that I need to fill. Display is bright blue and uses three wires. Thanks for the idea mate....
  7. The Following User Says Thank You to clubbyr8 For This Useful Post:
    ova50 (20th May 2014)
  8. #25
    Nov 2011
    The blue one in the small size is: http://www.ebay.com.au/itm/0-36-DC-0-30V-5V-Blue-Digital-Voltmeter-Voltage-Meter-Low-Power-Flashing-Alarm-/390840782051?pt=LH_DefaultDomain_0&hash=item5affed 0ce3
    Pitty you had ordered it. As I had mentioned, check the sizes on their listing.
    Was a CRD
  9. #26
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    Excellent write up ova50!!! How do you find the rear Anderson connector housing? Also what is the ferrite clamp (noise suppressor) used for next to your 5AG fuse?
  10. #27
    Sep 2014
    Thanks for detailed process.
  11. The Following User Says Thank You to v502 For This Useful Post:
    ova50 (27th October 2014)
  12. #28
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    a job very well done. thanks for the post
  13. The Following User Says Thank You to blocko05 For This Useful Post:
    ova50 (10th June 2015)
  14. #29
    Jul 2014
    6 Post(s)
    For what it's worth Cuppa, I've hooked my dual battery solenoid up to my winch switch in a way that disconnects the dual batteries when the winch is activated. Given my winch can draw 500A at max draw, and my isolater is only rated to 150a, it just wasn't going to cut it. Granted, we should only be seeing 250a to each battery when connected in a winch scenario. Given that most people that I've seen with dual batteries tend to have the second battery as an AUX deep cycle type battery, they don't tend to deal well with big current draw the same way a normal crank battery will.
    My crank battery is 800cca or thereabouts, and it dragged my patrol with a navara on the back, single line up a hill for about 30 minutes, with it's only breaks being to setup the next tree/winch. About 300m of winching 2 vehicles at the same time up a big ass hill with 0 traction (granted, I wasn't stuck, just too slippery to get up the hill) and the battery handled it fine. Gave it a good charge when I got home on the trickle charger but all seems well.
  15. #30
    Jul 2014
    6 Post(s)
    Woah, sorry, didn't realise this was such an old post haha
