Results 1 to 10 of 16
Thread: Diff Bracing
    Advanced Maxgq's Avatar
    Mar 2013
    nunawading, Vic
    Post Diff Bracing
    Who here has braced the front diff on their gq? If you have, how did you go with sump clearance? i have read that it may be an issue... my car has 2" suspension and 2" body lift
    *TD42* 2 inch suspension, 2 inch body, dts turbo, 3 inch exhaust, twin lockers, bighorns
    should be right are you using 50 x25 x 3 RHS sliced on an angle.
    You'll also need the small weld on piece for the ball knuckles
    http://www.ebay.com.au/itm/Nissan-Pa...item27f69da341
  4. The Following User Says Thank You to threedogs For This Useful Post:
    Maxgq (10th April 2015)
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Have braced my front and rear diff. Haven't had any clearance issues as yet.
  6. The Following User Says Thank You to Parksy For This Useful Post:
  7. #4
    43 Post(s)
    Yep. Braced mine.
    Made absolutely no difference to clearance as you brace the top side, not the bottom.
    43 Post(s)
    Here is a pic
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
  10. #6
    Here is a pic
    did you remove to weld or do in sitcu
  11. #7
    43 Post(s)
    Yea did it when I had it all apart to do the rebuild.
    North brissy
    Did you guys make sure it was straight pre and post welding?
  13. #9
    Jan 2013
    Nowra NSW
    5 Post(s)
    Nope. Just winged it and hoped for the best. But the last wheel alignment shows that both wheels are almost at 0 degrees so all good.
    How do you check for straightness?
  14. #10
    43 Post(s)
    Yep.
    And braced and kept heat even.
