Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: CTEK D250S Dual
  1. #41
    Well its all in and connected. I started the car up, lights came up on the ctek, the power light, the alternator light and the service battery light. I checked the charge voltage and the crank battery is getting a charge but the aux isn't. new battery there so maybe its charged enough sitting at 13.5V.... I can't see anything in the three whole pages about voltage cut-off etc etc..
    Ooops my bad, post deleted wrong thread
    Jul 2012
    N/a
    If the starter battery is charging or below required volts I think around 10.5v then the ctek will not charge the AUX battery until the starter hits 13.4 or 13.7v just from memory when I had mine in the gq
  4. #43
    Quote Originally Posted by Dinger View Post
    Hmm. The alternator is putting in around 14v to the starter battery though. It say I don't need to earth the starter battery to the ctek. Then I see a Youtube vid from Baintech where they say to do...Paranoia is kicking it, again. Lol. Last thing I want is to eff another aux battery and have warm beer.
  5. #44
    I would connect Solar, Cranker and Aux (esp if that is the Baintech recommendation) -ve to the Ctek.
    It eliminates any poor earthing or high resistance return.
  6. #45
    Expert clubbyr8's Avatar
    Penrith, NSW
    3 Post(s)
    Mudski, how did you go with this? Looking at getting a D250S soon. I've got a CTEK MXS 5.0 and the thing is brilliant.....
    GROOVY GUVII
  7. #46
    Quote Originally Posted by clubbyr8 View Post
    All fitted up well mate. It works as it should. It was a lot bigger than I though it would have been though. I had it fitted in the engine bay next to the aux battery, but now I am doing the conversion I have removed it for now so theres room in the bay for ease of fitment of the new motor. Well, I removed the entire aux side and all wiring so I will start again once the new donk is in and running. I think I will mount in under the lhs dash somewhere this time, to keep the heat away from it.
    Although I do like the redarc BCDC1225 better, as I have one of those in my camper, this was shite easy to wire up though. Very impressed by this.
    clubbyr8 (17th July 2015)
