Results 11 to 20 of 31
Thread: Time for suspension
    43 Post(s)
    That's want I want to do 2" life, do bump stops need to be touched if using 2-4 shocker? Will definitely be looking at brand name shockers.
    If you go with a +2" shock. No.
    If you go a +3 or more then yes.
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    jay see (15th March 2015)
    49 Post(s)
    He's probably going to need extended links anyway even with a 2inch lift. The sway bar is supposed to be dead level and with a lift they wont. Plus the disconnects will be adjustable/ extended.
    I could do this later.
    I like this idea of the extenderd because my last 4wd drive i snapped the sway bar link was a bit of a dog on the road but the flex was improved. Will see if i can dig up an old photo.
  5. #13
    43 Post(s)
    I could do this later. I like this idea of the extenderd because my last 4wd drive i snapped the sway bar link was a bit of a dog on the road but the flex was improved. Will see if i can dig up an old photo.
    There are 2 options you can go.
    You can extend the factory disconnect or replace them with something superiors extended manual disconnects.
    Either way you get the best of both worlds
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
  7. #14
    As I mentioned in the PM Ill meet you at Airport West they have to have specials for their Grand opening.
    I heard Easter but to me that doesnt make sense as a lot go away
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #15
    49 Post(s)
    I heard Easter but to me tha eht doesnt make sense as a lot go away
    Thanks John
    Keep us all posted, we all like specials.
  10. #16
    49 Post(s)
    This is another thing at can be done later if needed.
  11. #17
    49 Post(s)
    No Sway bar.
  12. #18
    as I always travel light I would like a slight down hill look.
    Why is that? How often do you tow your camper?
    Wouldn't you rather the car sitting straight when you're not towing (probably 90% of the time) compared to the odd time when you will tow?
  13. #19
    Patrol Freak gaddy's Avatar
    redlands
    To me suspension is a personal choice , what one person thinks is best for a given task , may not suit everybody , I tow most weekends and heavy at that , personally I don't like airbags or spacers , so for me the hardest springs I could get ( kings for me ) , which by the way aren't as harsh as people think , but my family's safety when loaded is paramount ! By the same token most of my 4wding is beach , or dirt roads ,
    We all have different needs , which means many different set ups
  14. #20
    49 Post(s)
    True. That's what makes it difficult, we are spoiled for choice.
