Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 89
Thread: Air box mods
    Those cobra adaptors are made by Donaldson. Hitachi construction in Campbellfield are Donaldson agents.
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    hpd offer that 3 inch adapter ur chasing but not cheap, at 100 bucks.. id just go with the plastic one mudski posted with a link to..
  4. #13
    I wont require that adaptor as I'll be tig welding a piece of Stainless about 50mm to the SS lid.
    Just remember I have a mate up Sapphire way that works in a big Tractor dealer ship, Ive
    emailed him regardind the rubber cobra 90. Nearly have all the bits sorted, saw that guy who wanted $150 for a few bits to convert the lid
    But its easier for me to cut a new lid, piece of cake to seal it.
    Its a lot of mucking around I hope the gains are worth while
  5. #14
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    Looks the goods, looking forward to reading your results.
    02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
  6. #15
    Not sure if the out come will justify the expense, but it will look neater I hope
    thinking about wrapping the boost and intake pipes in a thermal reflective bandage.
    hoping that will keep gases going in cooler, even a little bit would help
  7. #16
    22 Post(s)
    The issue is the airbox itself, not the lid.. have you noticed when cleaning the filter that the majority of crap is concentrated right infront of the air box entry. If the airbox itself flowed well, the crap would be allround the filter.
    IMHO, dont waste your time and money on a lid design. Put that towards an airbox that will actually perform.
    96 GQ coil/Cab
    08 G6eT
  8. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    benno77gu (7th April 2015), threedogs (12th March 2015)
  9. #17
    330 Post(s)
    http://pages.ebay.com/link/?nav=item...d=261800897797
    Check that link John, what you are trying to do has been available for quite a few years in kit firm
  10. #18
    Patrol God Stropp's Avatar
    31 Post(s)
    that link doesnt go anywhere Darren.
  11. #19
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    Not sure if that theory is correct, yes in a standard air box lid the dust particles will form in a area very noticeable to the eye, But I would also suggest this is due to the restriction from outlet, for example simple testing by blowing from a larger inlet to a smaller outlet will always concentrate the airflow into a airflow zone area which is what we see when looking at a standard airbox without mods, allow a similar sized out let to inlet for airflow and there will still be 'pressure points's' but less restricted that we see on a ZD airbox as standard, therefore should allow better breathing of air and more circulation around the air filter than what we see in a standard airbox, ie bigger inlet smaller outlet, same size inlet same outlet..or less restrictive outlet, I think you can see what I am trying to say.
  12. The Following User Says Thank You to SG1 For This Useful Post:
    threedogs (9th April 2015)
  13. #20
    22 Post(s)
    Quote Originally Posted by SG1 View Post
    Yes mate, I do understand what you are saying, but I still stand by my comments (probably didnt word it so well), there are some good airbox setups on the market that will way out perform the zd30 configuration, modified or not.
    96 GQ coil/Cab
    08 G6eT
