Page 472 of 1054 FirstFirst ... 372422462470471472473474482522572972 ... LastLast
Results 4,711 to 4,720 of 10540
  1. #4711
    I like shiny
    Shiny is good did you use POR15 or black enamel??
    Looks awesome BTW
  2. The Following User Says Thank You to threedogs For This Useful Post:
    katwoman (27th February 2015)
    Nov 2010
    Getting a life...
    38 Post(s)
    Shiny is good did you use POR15 or black enamel?? Looks awesome BTW
    Quick dry enamel and hardener.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. The Following User Says Thank You to katwoman For This Useful Post:
    threedogs (27th February 2015)
  6. #4713
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by Apollofish View Post
    Geez hope it's not a dream, winner
    I was going to get new tyres for winter 2016, so I'm in front no matter what the outcome is.
    Saved me quite a few $. Also gives me a chance to make sure the fault has been rectified by Cooper.
    Macca
  7. #4714
    Rust treated and then fish oiled the battery tray. I also glued about twenty odd strips of inner tube in parallel lines under the plastic tray, in the hope it will let any moisture escape from between the two surfaces.
  8. #4715
    43 Post(s)
    Just re ran the main power wire from secondary battery to rear.
    Replaced the 6mm twin core with a single 10mm cable.
    Moving the fuse bank to the rear so all the bits will have fuses closer.
    Placing a 50A breaker up front.
    Anderson plug on the fridge.
    And placing an Anderson up front for solar panels. A better connection than alligator clips.
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    lucus30 (28th February 2015)
  10. #4716
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Sounds like what I need to do
    Lucus30's 1999 GU ST TB45E
  11. #4717
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    new wiper blades
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  12. #4718
    43 Post(s)
    So today I've repaired my fuel pickup after the float parted ways.
    Re moulded the mount and soldered the wires. Will buy a new one, and then then place the repaired one into the sub tank.
    Fixed my gauges. Due to the values being all different one could only assume fingers stated playing when dash was apart for cleaning.
    So I've re set the needles. And now all good.
    While pickup was out I adjusted the float to suit my breather mod. So now it reads the whole tank, not when its 1/4 empty.
    Installed my winch isolator rocker switch.
    Started mods on the draw system to tidy up the electrical.
    Still need to run the dual battery over ride wire and switch.
    Getting there
    465 Post(s)
    Stripped down the rest of the TD today. Next is too take the block in for its x-rays...
  14. The Following User Says Thank You to mudski For This Useful Post:
    lucus30 (2nd March 2015)
  15. #4720
    WA Wheatbelt
    23 Post(s)
    Did something different today.....drove my Patrol on the road - towing a trailer. lol
  16. The Following 6 Users Say Thank You to DX grunt For This Useful Post:
    BigRAWesty (2nd March 2015), Clunk (2nd March 2015), katwoman (2nd March 2015), Stropp (1st March 2015), threedogs (2nd March 2015), Winnie (2nd March 2015)
