Yes it is at Arkaroola, but I asked for the name & Sillers Lookout it is. No it’s not actually on the Skytrek (self drive 4wd route) but is on the accompanied 4wd ridge top tour. It was made famous in a TV commercial for a car ....... but for the life of me I can’t find a reference anywhere to what car it was. Does anyone know? Going up there in the back of a 4wd ute (a T*yota iirc) with a dozen passengers was pretty impressive. Virtually no revs & I was hanging over the side watching the wheels, & just the occasional half a revolution wheelspin.
So who should go next? Rossco for Arkaroola or TPC for Sillers Lookout, both correct, although TPC is a bit more accurate. I’ll let you decide whether you’ll be gentlemen or engage in virtual fisticuffs for the honour .......... The next pic put up will no doubt reveal to us all the outcome of whichever process you adopt! Ha Ha.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
