Results 41 to 44 of 44
Thread: Did you know, I didn’t?
  1. #41
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    one other thing to consider
    I have a Van 2200Kgs loaded
    I have 2 chains
    I have 2 Bow Shackles
    BOTH Bow Shackles are rated at 1.5t each
    combined max for BOTH shackles is 3t - well under my loaded weight - legal...........
    the individual shackle - either D or Bow does NOT have to be greater than the Mass being Towed - but combined (unless you only have 1 chain)
    a 3t rated Bow Shackle is rather large, and wont fit the chains anyway............
  2. The Following User Says Thank You to Bigcol For This Useful Post:
    BigRAWesty (25th February 2015)
    43 Post(s)
    Quote Originally Posted by Bigcol View Post
    one other thing to consider I have a Van 2200Kgs loaded I have 2 chains I have 2 Bow Shackles BOTH Bow Shackles are rated at 1.5t each combined max for BOTH shackles is 3t - well under my loaded weight - legal........... the individual shackle - either D or Bow does NOT have to be greater than the Mass being Towed - but combined (unless you only have 1 chain) a 3t rated Bow Shackle is rather large, and wont fit the chains anyway............
    Yea a 3.7t shackle is getting quite large.
    I had a student once who was adamant that an 8,000 Kg snatch strap meant that you needed a minimum 8 ton rating on the shackles shackles.
    I said 'I like your logic but there is one small issue' and showed him one
  6. #44
    Expert janderson's Avatar
    Bearii Vic
    Thanks Kallen totally agree why risk your pride and joy with junk hardware or even Marine which would only be Stainless.
    BUY properly rated shackles that suit the weight you are towing. or if you only have a bolt change it for a graded bolt, and zinc plated.
    Chain on my camper has 50mm long links maybe bigger but crossed under the towbar with rated shackles its not going anywhere,
    especially with the O'Brien coupling
    Just read the GoSee link by Cuppa. sounds strange as when I went to get my trailer rego'ed
    all they wanted was a current weigh bridge ticket,and receipts for all material used.
    Not once was I asked what chain or shackles were used, they didnt even want to see it.
    If I go and get some stamped chain I wouldn't be able to get a shackle big enough to cover the
    camper weight.
    I bet most caravans and camper trailers would fail the AS set, but who cares seems nobody
    $40,000 CT and a $2 shackle =
    Does every one here use rated shackles????
    This is whats recommended in QLD.
    I just set this up to make it easier to hook up. 3500kg rated. Chains on camper were to short anyway.
    1st G60 Then MQ Now GU
  7. The Following User Says Thank You to janderson For This Useful Post:
    threedogs (25th February 2015)
