Just soldered it in. Left myself about 300mm extra wire if I ever need to change globes
Would be nice to be able to unplug them but I can't find harnesses so will probably do the same, have had the lights waiting to go in since before Christmas.
If you want just use after market plugs. Though honestly I couldn't see why I'd need to unplug them so didn't bother. If the need arises I'll put a plug in when I chop the wires
I put a plug in mine. Easy to swap if you every break one or to just change a globe. Figured while I was at it I may as well over do it then i don't need to do it again
Today I modified my new steel bar to accept the park/blinker lights from my original stock aluminium bar and mounted the hawse fairlead. Dramatically changed the look.
Turned it from a cow cockies bar to something worth owning.
