Results 1 to 5 of 5
Thread: Hose size for transmission lines 2001 GU Auto
    Mar 2014
    Holsworthy, NSW
    Hi all,
    Does anyone know offhand the internal hose diameter for the 2 hoses that run from the transmission to the radiator? I need to buy a short length to loop them around and connect each other. Looks to be around 6mm?
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Trans cooler hoses are 5/16"
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
    Xtreme (20th February 2015)
    which would translate to 8mm
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #4
    Morayfield, QLD
    I should add that aftermarket trans coolers (my Davies Craig anyway) use 3/8"
    John
  8. #5
    Aug 2017
    would this be right for a 99 GU (4.5lt)
