Results 1 to 6 of 6
Thread: moving with out the panhard being conected
    mackay
    with the cyclone coming i should move the gu all the way into the shed. can i move it forward with out the panhard being connected ?
    193 Post(s)
    If it's the front should be able to drive it sloooowly for a little bit. If it's rear you will have to push it or tow it or diff will just move sideways when u try and drive. All the best with it - looks a little nasty. . .
    22 Post(s)
    It wont steer without the front panhard it will just move the body
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Rossco (19th February 2015)
    mackay
    thanks just wanted to go fwd 3 feet so all good
    193 Post(s)
    Yeah sweet, all good. . . Good luck with the storm mate.
    Jun 2014
    Use a tie-down strap with a ratchet, do a cross tie from the axle to frame , compress springs a litlle ... move carefuly .
  9. The Following User Says Thank You to cos For This Useful Post:
    happygu (20th February 2015)
