Page 2 of 30 FirstFirst 123412 ... LastLast
Results 11 to 20 of 294
Thread: 04 gu bus...
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    First .... Your drivers door is locked now, and won't unlock? If this is the case, then you are in a bit of trouble with this, as if you can't get it to unlock, then you will have to remove the inner door trim to get to the lock itself ( which may mean that you need to destroy the trim by cutting a hole in the door trim on the inside, or you can remove the front guard, undo the door hinges, and swing it away enough to pop off the trim but that is a lot of effort ).
    I would take it off-road on some bumpy stuff, and see if you can get the lock to jiggle a bit, and try again .... you could be lucky
    Second...... I would get under the bonnet with a water dispersant, such as WD40, and spray all the electrical connections - even unplugging, then spray and reconnect - with the ignition off so you don't introduce any extra fault codes
    Third .... this must have been something you have done, as it was fine before you plugged in ... Check fuses, and then check the polarity of the plug against the polarity of the wiring of your fridge with a multimeter and your eyes too
    Fourth .... Patrols can have slight wobbles in the steering wheel - that is a known issue, but these should be minimal ... check the wheels and tyres - rotate the back to the front to see if it makes a difference. If you then need to, get you tyres balanced at the tyre dealer you trust, then re-assess from there.
    Fifth .... can't help you
    Cheers apreciate ur help/feedback
    Feb 2015
    Thanks all for the feedback... original plan was to drive new bus upto kalbarri fora long weeknd.. that plan didnt go as exspected so loaded up the 80 and about to hit the road... will be getn into diagnosing the problems when i get back on sunday... i dont like the thought of having to remove guard or butcher the trim to get at the lock mechanism... again thanks for all the help.. and more than willing to hear any other recomendations/feedback... will post pics and post details of what i find when i get bak frm my trip... hopefully catch a good mullaway so im not fealn so dwn...
  4. #13
    43 Post(s)
    It'll be a bit of stuffing around but I'd remove the drivers seat. That'll make it easier to remove the trim
  5. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Bob (19th February 2015), mullet_hunter (19th February 2015)
  6. #14
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    X2 Westy.....
  7. #15
    Feb 2015
    how do i change my thread name to my gu lemon?
  8. #16
    Feb 2015
    Just got back frm trip upto kalbarri...
    Fishn was good.. slayed a few tailer n a mothr mallawayy anda couply sharks...
  9. The Following User Says Thank You to mullet_hunter For This Useful Post:
    Clunk (24th February 2015)
  10. #17
    Feb 2015
    Started on fixing the gremlins today... pulled out old head unit and replaced with new one.. wiring was dodge job.. twisted wires wiv silver duct tape everywhere... power wires frm the battery non fused and going to nowhere... also looked into why the door will lock/unlock but why it wont open the drivers door frm both the inside or out... seems the lockn mechanism has called quits. So getn price for new one and for locksmith to fit it up... wasnt keen on spendn a good part of a day trying to remove door trim n fit up another lock mechanism... so thought id palm that job off to the experts..
  11. #18
    Feb 2015
    Tomorrow will remove all plug/sensor wires and wd40 them.. leave the hood up and hopefully giv the engine bay a good dry out... also look at replacing glow plugs...hopefully sort out this random high idle/hrd starting issue...
  12. #19
    Feb 2015
    Will also be lookn at getn wheels balanced to help iliminate the death wobble...
  13. #20
    Feb 2015
    Pic of my bus/lemon... hopefully sort out the gremlins and she wil do me proud...
