Results 11 to 20 of 35
Thread: Empty Rod holders
    brisbane
    Quote Originally Posted by wa 489 View Post
    I've been told by police that they aren't even legal with rods in them,believe it or not..they did let me leave them in there,
    Thats not the case in qld you can use them with rods but illegal if empty.. thats how petty this law is.
    Patrol Guru
    NT
    Well I want a new law stating that maxtrax can only be carried of you are coming and going from an approved 4wd destination. Too many posers!
  4. The Following User Says Thank You to P4trol For This Useful Post:
    megatexture (27th January 2015)
  5. #13
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    It amazes me some laws and can understand the theory on how it could possibly cause harm to a pedestrian if you were to run them over, but still doesn't mean I agree with it, as if you hit a pedestrian with a 3t patrol with a bulbar its going to do some damage regardless, then there is your hooks on winches or even recovery points underneath and a couple of diffs if they go under the vehicle that are surely all going to cause a really bad day for all in involved.
    If I was allowed to use them I would have them on all the time, but then I would use them.
    02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
  6. #14
    The law has been made to protect a victim in a survivable low-speed impact.
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Bloodyaussie (27th January 2015), MudRunnerTD (28th January 2015)
  8. #15
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by SG1 View Post
    If you had to choose, would you prefer to be hit by a 50 km/hr patrol with, or without a rod holder in your stomach?
    Hello from Under Down Under!
  9. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    mudnut (28th January 2015), MudRunnerTD (28th January 2015)
  10. #16
    Really unless you were a professional fisherman, but I can't even see them using them.
    We used to cart our surf rods around wired to the door handles but you cant do that on modern cars.
    Whats wrong with carrying them on your roof rack, tie the front down and place a flag maybe on the back
    if too long, see just saved you $50 from buying the stupid things in the first place
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #17
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    That is correct, and I think it's actually quite a good law. It falls under the same category as not having sharp edges on your bullbar.
    5 minutes if that to remove/refit when needed. If you do it regularly then you can get some that a lot in with a pin, 10 sec job.
    No reson not to.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  13. The Following User Says Thank You to Punderhead For This Useful Post:
  14. #18
    Expert Hardyards's Avatar
    Townsville
    "Whats wrong with carrying them on your roof rack, tie the front down and place a flag maybe on the back"
    Some setups like mine don't have the roof rack to support this. I use my Rod holder when I visit the Cape/beaches to hold a surf rod and non-detachable bait caster. The boat is affixed to the top of the camper so no room there either. I am not a professional fisherman barely rate as an amateur! The holders work for me, and I will be (now) taking it off when not in use. (My ute not a daily driver, only used for camping/fishing trips) Corrugations are very unforgiving to fishing gear not adequately stored.
    2006 GUIV DX 4.2 TDI Ute, Bullbar with Warn winch, Narva round spotties, scrub bars and side steps, Snorkel, Dual Battery system, Waeco fridge, 2 x Narva spotties an 80W solor panel on roof, Custom tray, 3" Redback exhaust, Bluemax 2 - EGT/Boost Oil press/Temp and dual volt gauges, Lifted, front locked and fully loaded......
    If you can't stand behind our troops, feel free to stand in front of them!
  15. The Following 2 Users Say Thank You to Hardyards For This Useful Post:
  16. #19
    brisbane
    Or don't get in front my car when I'm doing 50 kph and were all happy...
  17. The Following User Says Thank You to megatexture For This Useful Post:
    Hardyards (28th January 2015)
  18. #20
    yep just take em off when not in use...I had the local coppers stop me and asked me to spin them around behind the roo bar once,now I just whack em on when going down the coast..omly live a few km to the track so I'm fine..whan I got stopped before I was 1000km away from home with rods in them as I was coming back from up north..i think the cop was just having a bad day really..
  19. The Following User Says Thank You to Avo For This Useful Post:
