Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: air filters
    brisbane
    The recharge kit is about as much as a paper element though, but it does do at least two recharges.
    Isn't it just oil? Go to the local fish and chip shop I'm sure they would give you heaps
  2. The Following User Says Thank You to megatexture For This Useful Post:
    Clunk (15th January 2015)
    No fumes from the air cleaner oil mate...
    Agree but with a rider for engines tha are known to be sensitive to MAF issues...
    Don't use too much oil when you load the filter after a service and definitely don't put the filter staright back in.
    Give it a 1/2 hour or so after oiling.
    On my Chevy I could probably start it up and tip a litre down the snork and let God, Gravity and Dumb Luck sort it out but on the other end of the scale a CRD?... not so much
  5. The Following User Says Thank You to the evil twin For This Useful Post:
    threedogs (16th January 2015)
  6. #13
    The spray on recharge kit does the filter around six times and wasn't that dear. I'll see if I can find where I get mine from.
    Edit, I paid 24aud for the kit. Comes with the cleaner and spray on oil. From engine parts Australia. ..
  7. #14
    I can remember a thread a while back about fumes , but I think ET hit it on the head
    by not replacing the filter straight away, and not applying too much,
    Maybe some are thinking of those foam re usable filters
  8. #15
    With the spray on oil is quite easy to use and not over oil the element... Plus having two elements the second one has been sitting for a while pre oiled so it's good. But yes you need to leave them sit for a while before you put it in.
    Also, one of the reason why I use these filters is there is less rubbish and I can simply change my filter even after being on for a week if I want to because of a dusty day out in the bush.
  9. #16
    I've been buying from Autobarn, probably getting reamed. I can't remember what I've been paying for them.
  10. The Following User Says Thank You to Winnie For This Useful Post:
  11. #17
    Jun 2013
    Woodford
    Sorry for not replying earlier. You all talk about being good for diesels, I have a 4.5ltr petrol would it be the same for it.
  12. #18
    Quote Originally Posted by aj_vmax View Post
    Yep...........
  13. #19
    Yep...........
    Nope...........
    Actually I wouldn't have the foggiest, I'm just trying to wind Clunk up... he's been a bit quiet.
  14. #20
    Jun 2013
    Woodford
    The evil twin all good I understand
