Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 85
Thread: Front and rear wheels not spinning at the same speed?
    Legendary happygu's Avatar
    Covo,
    I would also take up Heath's generous offer of assistance, as there does seem to be an issue, and two sets of eyes and hands will be helpful
    Mic
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Yep, i think another set of eyes would be good. Just checked turning tail shaft and watching wheel. about 4.3 turns for 1 turn of the rear wheel. about 5.1 turns for the front wheel to turn once.
  4. #23
    Well, I would call it as 4.3 ratio in the rear but jury is still deliberating on the front... 5.1 is "interesting" so maybe 4.6 ratio out of a 2.8 or 4.3 and something else is stuffed?
    What ratio is on the compliance plate?
  5. #24
    Dec 2012
    Coffs Harbour
    HG43 on the plate so I believe that is 4.3.
  6. #25
    Quote Originally Posted by Covo71 View Post
    Yep, sure is.
  7. #26
    Dec 2012
    Coffs Harbour
    Anyone on here sell diff gears? How hard is it to change over?
  8. #27
    4.3's are a fairly common size.
    Should be able to pick up a set from either the wreckers, or maybe your local fourby shop tnat is putting in difflocks
  9. #28
    465 Post(s)
    Not so hard but a bit of work and setting up the backlash etc etc. With the right tools and know how, it would be a few hours work just to remove and refit the gears. Not counting the removal of the centre.
  10. #29
    Advanced heaths_gu's Avatar
    Oct 2014
    Bathurst
    You could try K&A 4wd wreckers in Orange to see if they have a complete centre. I got one off them about a year ago for my old hilux and from memory it was $300
  11. #30
    Dec 2012
    Coffs Harbour
    Hi Happygu, do they not still use it if they put in lockers?
