Results 1 to 10 of 12
Thread: Waeco CFX Power draw
    Feb 2012
    I am going to Fraser Island in February and was curious to know how many amps my fridge drew from my aux battery.
    Searching thebay I found a little power meter thing that could calculate amps,watts battery voltage etc.
    I hooked it all up and started timing the 24hr at 730pm,the fridge internal temp was 29degrees,the thermostat set to 2 degrees.
    As a worst case scenario I did the test with an empty fridge cause I know it takes more to keep cool empty so it would leave a little buffer in the real world(half beer half food)
    After 24hrs on a hot day(34degrees,still 30 at 730pm) the draw was 31.55a/h,probably a bit more than I expected but gives me a good indicator for battery preservation and probably explains why my last 100ah marine battery lasted 12months.
    Hope this is helpful
  2. The Following 2 Users Say Thank You to ben ren For This Useful Post:
    AB (16th January 2015), katwoman (16th January 2015)
    583 Post(s)
    What size fridge do you have?
    Feb 2012
    Sorry forgot to mention CFX 50 with cover
    43 Post(s)
    What device did you grab?
    Many use what is called a "watts up meter".. Very popular in the rc model world
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    That seems really high. My 60 litre wouldn't be any where near that. Do you pre cool it on mains first ?
    Lucus30's 1999 GU ST TB45E
    Quote Originally Posted by lucus30 View Post
    From ambient to 2 degrees, on a 34 degree day with an empty compartment I actually thought it was low useage esp for a danfoss style Compressor.
    It is only around 1.3 amp/hours for a fridge pulling down over 30 degrees.
    The factory rating is .8 amp/hours on less load and nominal voltage.
    For a Waeco thats not bad power figures IMHO.
  9. #7
    Feb 2012
    Nah mate straight on 12v.
  10. #8
    Feb 2012
    If you search "watt meter " it's a blue box,there's a few different ones but I went blue
  11. #9
    Does it look like this I think a great item to monitor battery.
    I was able to find a US regulator on my solar panel with it.
  12. #10
    Feb 2012
    Yeah that's it three dogs,I put Anderson plugs on each side for solar panel monitoring too.
    Great little thing and cheap too
