Results 1 to 5 of 5
Thread: Dawes valve Vs Boost controller
    Oct 2014
    Muswellbrook NSW
    Can anyone tell me the difference between a boost controller and a dawes valve ?
    Oct 2014
    Muswellbrook NSW
    Sorry guys, I just read through the forum and answered my own questions
  4. The Following User Says Thank You to Dananjen For This Useful Post:
    Drewboyaus (26th December 2014)
    Oct 2011
    Essendon
    Quote Originally Posted by Dananjen View Post
    You get a gold star! LOL
    Sent from my iPhone using Forum Runner
    For other who are searching and found this thread, the difference is the Dawes is used for Variable Vane Turbo's which are vacuum controlled turbos and do NOT have a wastegate, like the ZD30 Patrol, 2.5Ltr Navara, Tritons etc etc. The boost controller the OP has shown is commonly used for any other setup that uses a boost pressure controlled waste gated turbo. Like a TD42, RD28, ZD30 Navara etc etc.
    brisbane
    same reason we don't need a boost and vac gauge only boost, if you get a boost/ vac gauge and try to fit it using supplied instructions it will run in vac and only spike into the boost zone occasionally if your lucky.
  8. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    mudski (29th December 2014), threedogs (29th December 2014)
