Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: DIY Ironman Snorkel
    Feb 2011
    Shed
    45 Post(s)
    DIY Ironman Snorkel
    Wonder how much a guard costs if I stuff this up??
  2. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    Clunk (20th December 2014), Stropp (20th December 2014)
    well I would say, if your rear draw building skills are anything to go by.................... Then you may need a few bwahahahahahahaha
  5. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    cgm (20th December 2014), MudRunnerTD (20th December 2014), Stropp (20th December 2014)
  6. #3
    First thing I'd do is make sure its the correct guard,
    I've heard stories of fitters drilling the 5" hole in the wrong guard
    Surely not you though, what are you using on the "A" pillar
  7. #4
    Good luck mate. Keep the template when your done mate.
    Hey! Don't Fark it up
  8. #5
    brisbane
    You will be right mate, I fitted one with a mate using a 5mm drill bit and a steak knife because he was a tight arse and didn't want to buy a hole saw! And don't hold back on the sealant!
  9. The Following User Says Thank You to megatexture For This Useful Post:
    Majestic (28th December 2014)
  10. #6
    Is it done yet, or have you gone to buy a new guard?
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #7
    brisbane
    He's already got the guard and waiting for the colour match to dry
  13. The Following 5 Users Say Thank You to megatexture For This Useful Post:
    BigRAWesty (20th December 2014), Clunk (20th December 2014), Majestic (28th December 2014), Stropp (20th December 2014), TPC (21st December 2014)
  14. #8
    Feb 2011
    Shed
    45 Post(s)
    Stupid bastard forum runner! I just did the most intelligent helpful post from me ever and the forkn thing crashed while uploading photos!!!!! &@!?EURĄ+*%#
  15. #9
    Feb 2011
    Shed
    45 Post(s)
    Try again
    All done! Without eff ups I think?
    The instructions are very vague to say the least, so if you don't feel confident don't give it a go, thinking the instruction manual will get you outta the poop. THEY WONT
    Tape up you panel with low tac masking tape. There is a shipload of rust making swarf/chips flying around. I used a rubber coated magnet to run over everything after. Also use ya bloody safety glasses when using the hole saw!!
    The template edges weren't close to meeting the panels where they were meant to, but the corners did so I bit the bullet. Hope for the best, expect the worst, and take what comes. Tape it down to mark all the holes, remove template and drill/hack away.
    Once all drilled, before removing the tape I filed and painted all holes with touch up paint (inside and out) giving it a few layers.
    HINT: Make sure your step drill isn't dull like mine was on the 16mm, I had to put a bit of force into it and dented the panel, it turned out ok as it pulled back when the snorkel was done up. But at the time with only 1 beer, raging hot sun, it stressed me unnecessarily. I also managed to get white overspray on my black plastic guard, so thatll be todays job getting that off.
    Don't be shy with the silicone and make sure its sensor safe. Where the snorkel goes through the panel you cant see the connection once installed, you can get your fingers around it just, but it has left that lingering doubt that it is 100% sealed. I used half a tube on this connection and had the shit everywhere.
    The connection to the existing air box in my opinion is a bit poor. It buts up and fixed with silicone, again be liberal with it to get that good seal.
    In all the hardest part is probably getting the headlight assembly and airbox out and back in without busting anything
  16. #10
    Feb 2011
    Shed
    45 Post(s)
    Nup no pics forum runner crashes whenever I try BASTARD
  17. The Following User Says Thank You to growler2058 For This Useful Post:
    bazzad (22nd December 2014)
