@ Macca that lower bar that goes horizontal, I lot of members in my club have extended it about 100mm
To accommodate the VHS antenna, I used to make a bolt on extension, as down here space for that style antenna is
at a premium, bullbars are a no no.
Whats acetal?
Acetal is a machineable plastic / nylon that has low friction but high compression resistance. Ideal for this type of bushing. No good in suspension as it has no give. I have been assured it will cope with our terrible corrogations. Will get a 50 mm diameter piece 200mm long and get 2 bushes made 30mm diameter with a 10mm collar for the load bearing part. 12mm HT bolts for the pivot so should be sweet.
I have some dark blue poly something here that was machined for a body lift so I take it
it would be similar, this stuff has no give at all.
Being a pod I thought you would swing down using bonnet style struts.
I did see one build years ago for a lady doing the big lap.
They mounted two wheel/tyre combos behind the cabin.
and "caged" them in when open these "cages acted as a tracks to roll the wheels down
no lifting at all. I thought at the time what a great idea
So if I have it right you'll have a bush in the base not unlike a leaf spring bush[yellow]
and a similar bush at the top, will these be greasable or not required ?
you could have used two plumbing blocks as well I suppose
That's interesting John, I was originally going to use a bearing, needed one to take thrust or side load. Was told due to the corogations the bearing wears and they won't run smoothly.
The Bush will be exactly like a leaf spring Bush, I have been assured it will cope with the loads applied.
Also intend to have the latch end located on a pin, bushed as well so movement will be limited.
Need wait until after the break to get the bits made to finish it.
