Results 1 to 10 of 12
Thread: Battery Terminal / Factory Earth Question
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Hey all
    I need to get a new negative battery terminal that will allow the connect of a few accessories, namely a winch start with - however it appears that the factory earth connection to the battery terminal is soldered in? Patrol is a 3.0L CRD GU6
    I assume this is something I'll need to get an Auto Elec to fix up - or is there another way around this? And how much would something like this cost?
    Cheers appreciate your help
    Cut it and crimp a lug onto it
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    I'm an auto sparky by trade, cut the old terminal off close too the terminal and go down your local auto sparky for a cable end ( also known as a battery lug).
    I think the size you will need will be a 16-8 or a 25-8. You can just use a normal set of crimpers for them ( will be tight but do fit).
    Otherwise remove the whole neg cable and you can hammer the lug flat onto the cable.
    Bit of heat shrink and good as new
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  5. The Following User Says Thank You to big_fletch For This Useful Post:
    Bacho86 (6th December 2014)
    What Winnie or Big Fletch said... just make sure you get an excellent crimp result by using hydraulic crimpers or soldering... GU's HATE earth issues
    OR
    Replace the factory -ve cable with one from Repco/Supercheap/etc that has a ring termination on both ends
    Quote Originally Posted by big_fletch View Post
    I would either use a proper set of crimpers (your local electrician or auto electrician will have them and probably do it for free) or if you use Fletch's method I would fill it with solder
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #6
    Mar 2011
    14 Post(s)
    Thanks for the responses guys - unfortunately I don't have anything large enough to get a crimp it that I could guarantee a good results, so a trip off to the Auto Elec it'll be
  10. #7
    Mar 2011
    14 Post(s)
    OR
    Thanks ET - I've seen those ready made cables before in Supercheap, just was never sure about the quality? Would it be as good as the factory ones?
  11. #8
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Where do you live mate? You can come round and do it at my place with my crimper if it suits?
    I live in Ferntree Gully
    Lucus30's 1999 GU ST TB45E
  12. #9
    A pair of bolt cutters do a pretty good crimp too
    I am in Lara and could crimp it for you of mate. Or just take your cable to an auto elec and ask them to crimp a new end on it. Will be cheap and they will do it while you wait.
    Th Supercheap or Repco earth straps will be fine mate.
  13. #10
    Mar 2011
    14 Post(s)
    Hey mate appreciate the offer, I live in Ferntree Gully too so that's nice and local!
    I'll let you know how I go, but it wouldn't be until next weekend anyway if that suits you - flat out with family / Christmas stuff this weekend.
