Results 1 to 10 of 15
Thread: A/C blower stays on
    Advanced Snow Patrol's Avatar
    Jul 2014
    Snowy Mountains NSW
    A/C blower stays on
    Has anyone Had their blower fan stay on when they turn off the ignition????? I have a engine light on also after having fitted a dawes valve, noticed the fan about the same time as the light. Car was and is running great with no Limp mode. I have adjusted it to 15psi max and it sits around 10/11psi at 100kmph. Patrol is a 2008 crd.
    2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
    1980 MQ Ute (nearly forgot the indestructible farm Ute)
    one is a mechanical thing being the dawes the other electrical so I cant see how both are related.
    Dis connect the battery for 1/2 an hour and see how you go
  4. The Following User Says Thank You to threedogs For This Useful Post:
    Snow Patrol (13th November 2014)
    Jul 2014
    Snowy Mountains NSW
    I agree that is what confused me. I have had a poke around and it is my newly installed gauges that seem to be the cause of the blower running. I needed to find a switched wire for the gauges to turn on and that seems to be energizing the blower circuit. I guess Engine light was likely caused by a boost spike???? even though I did not see it go over 15 psi. Doing the battery thing. Might leave it overnight and find a new switched wire tomorrow arvo.
    Disconnect the switch wire to the gauge and then see if the blower still runs.
  8. #5
    Jul 2014
    Snowy Mountains NSW
    Turns out the wire that goes to constant (+) was live. Only used to save colour settings and so powered the accessories circuit. You were right mudski. Left the battery disconnected overnight but still has an engine light. Will have to get it reset. Or...... buy a scan gauge........ wifey is starting to tap that foot again.......
  9. #6
    Just go to a Supercheap auto. Its around $15 and they can reset the ECU for you. I stupidly took my Patrol to Nissan a while back for an ECU reset and for 5 minutes work it was $120'ish.
  10. #7
    Jul 2014
    Snowy Mountains NSW
    I wish it were that easy mudski. Nearest Supercheap is light years away, and as for the local dealership.... less said. I will sort it out some how. Still looking at a Scangauge. They have some neat features as well.
  11. #8
    Scan gauge it is for you then.
  12. #9
    Jul 2014
    Snowy Mountains NSW
    Scan gauge arrived.. Love new toys... Code was a P0401 blocked egr....silly computer.
  13. #10
    Yeah that will always come up. One to just ignore...
