4th November 2014, 08:12 AM
Shelf Life of Oils and Brake Fluids.
Hi Guys. Any Lubricants expert out there? I have around 10 liters of 10w40 fully synthetic oil as 1 liter of DOT5 brake fluid that was on stock for 4 years. All of them are sealed and we're placed in a dry storage space. Can any one tell me if I can still use them on my rig? Thanks.
4th November 2014 08:12 AM
5th November 2014, 12:50 AM
Come on guys. No one insights on this?
5th November 2014, 07:27 AM
oil should be ok patrol gu's use dot 3
OH LEATHER IS NICE
5th November 2014, 07:35 AM
Moderator
If they are sealed they should be fine. I would use it.
Check out my Toy -->
Rogue Dung Beetle
5th November 2014, 08:24 AM
Will there be issues if I used DOT5 instead of DOT5 on my rig?
5th November 2014, 09:39 AM
Dribble Master
Zhing1
No there won't be issues if you used DOT5 instead of DOT5, as long as your vehicle specifies the use of DOT5, then DOT5 can be used......... Otherwise you might need to use something that isn't DOT5
6th November 2014, 02:35 AM
Haha. I meant using DOT5 instead of DOT3.
6th November 2014, 06:08 AM
#8
on top of the brake fluid cap on the master cylinder is written your answer dot 3
they are different thicknesses and compress at a different rate
OH LEATHER IS NICE
7th November 2014, 09:47 PM
#9
I also found a gallon of engine coolant that's 5 years old. Is this still okay?
7th November 2014, 09:49 PM
#10
So I can't use DOT5 on my rig because it only specifies DOT3? I was under the impression that the higher DOT rating, the better. What could go wrong if it pushed thru on using DOT3?
