Results 1 to 10 of 10
Thread: Column or Pillar Mount Gauges?
    Oct 2014
    Coolum Beach, Qld
    I've bit the bullet and purchased Speedhut Pyro and Boost gauges for my ZD30.
    Problem is I can't decide on Pillar Pod or Column Pod for the install. The beauty
    of the Speedhut gauges is that they are very shallow in design to allow fitment anywhere.
    So has anyone had any bad experiences with either?
    I live in Queensland so don't seem to have the issue like in southern states regarding legality of pillar pod.
    I'd like to keep windscreen as clean as possible so this is why I'm considering the Column mount. I just haven't
    seen any Patrols using them.
    If any other suggestions regarding install I'm willing to listen.
    Thanks.
    Aug 2010
    adelaide
    pillar pods look great
    column pods might dlock the view of dash gauges
    pillar are easy to install
    OH LEATHER IS NICE
  4. The Following User Says Thank You to my third 256 For This Useful Post:
    TJCPATROL (12th October 2014)
    330 Post(s)
    I have a 2 gauge Pillar pod on my GUIV and this is where Nissan should have put these two gauges from factory. Perfect location in my opinion.
  7. #4
    Heres where my gauge is. No obstruction of gauges at all.
    Pic is taken on a angle too. Sitting in the drivers seat I can see both gauges clearly.
    So this leaves room to add more gauges later on a pillar pod.
  8. #5
    brisbane
    I've got 2 pods in the same spot as mudski's and it blocks nothing, unless your car idols under 1000rpm or you drive above 150kph
  9. The Following User Says Thank You to megatexture For This Useful Post:
  10. #6
    You can get pods now for drivers or passenger side now plus not only gauges but switches.
    In saying that I find the pillar pod easy to read and I don't have
    to look down, my eyes are always looking forward, M2Cw
    Autron pillar pod gauges incorporate a dual battery gauge, but $$$$$$
    might be better off building your own gauges to suit your budget
    PM sent but 4x4 Concepts do a triple gauge if needed as well
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #7
    Oct 2014
    Coolum Beach, Qld
    Thanks Mudski, I looked at these gauges long and hard before deciding on 2 separate ones. I'm worried that at over 6ft tall and column in high position I may have an obstruction. I see yours is not on actual column so would stay put. The one I'm looking at sits on column itself. That's my worry.
  13. #8
    Oct 2014
    Coolum Beach, Qld
    Hi mate. Thanks for that. So yours are in seperate cups behind the steering column, not in a double pod that sits on column? I like the idea of them sitting out of plain sight so long as they don't block any view. I have the steering column set in almost highest position when driving. Gives me something else to think about then.
  14. #9
    Oct 2014
    Coolum Beach, Qld
    Thanks threedogs, it's 4x4concepts I'm looking at. Only 2 gauges. Pillar pod looks very deep and bulky to me as my Speedhut gauges are.very thin and seems a waste of space. That's why I'm leaning towards the column pod. But trying to make sure they don't block any view. The gauges themselves have high value alarms that are user selectable so won't need to be looking at them constantly.
  15. #10
    Oct 2014
    Coolum Beach, Qld
    Ok I'll go with the pillar pod then.
    Next question is do I paint myself out is the colour match good?
