Results 1 to 10 of 11
Thread: my smallest welsh plugs wont fit
    Advanced elmo4eva's Avatar
    Dec 2013
    Hey all just wonder has anyone ever had this problem of the 7 smallest welsh plugs on the side of the motor not fitting
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Are they oversized by much? Put them in the freezer for a few hours, it should shrink them up enough.
    1999 GU 4500 dual fuel
    Il dado è tratto
    Dec 2013
    Nah mate there not oversize they seem like the proper size but there not u can push them in with ur finger they need to be like half of half mm bigger but they don't make that size they said
    Feb 2013
    Broadford VIC
    Doesn't sound right, have you tried a few places like Nissan and Repco maybe!
    Il dado è tratto
    Expert billyj's Avatar
    gordon
    3 Post(s)
    there too small, the welsh plugs should be a tiny bit bigger than the hole, its the interference fit that helps them to seal. measuer the holes with a set of verniers and then get plugs just a little bigger
    Sep 2011
    adelaide
    18 Post(s)
    G`day mate
    What type are they, cup or saucer?
    Saucer type normally can be pushed in the hole up to the shoulder then it is flattened slightly to spread the plug which locks it in the hole
    Cup type are pushed into the hole and the edge of the plug which has a larger diameter than the base then shrinks to the size of the hole locking itself in place .
    Hope this is of some help.
  8. #7
    Dec 2013
    I have stainless cup ones
  9. #8
    Sep 2011
    adelaide
    18 Post(s)
    You could try an engine recon shop or genuine.
    Why are you using stainless there`s no need and I would be checking that there is not a problem with electrolysis. I`ve always used steel or brass, and yes in the early days steel did rust but today its not common with the coolants we use.
  10. #9
    Feb 2013
    Broadford VIC
    Steel plugs are cheap and used as oem, brass is a common replacement. I've heard not to use brass on alloy heads and to use stainless steel on Diesel engines .....
    Il dado è tratto
  11. #10
    Dec 2013
    Oh tru I neva new that
