Results 1 to 8 of 8
Thread: 24v or 12v starter for GQ 4.2 Diesel
    Sep 2014
    Hi,
    I need a starter motor for my GQ 4.2 Diesel.
    When i search, i find both 24v & 12v to suit, which is the correct part?
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Quote Originally Posted by Zebinc View Post
    Hi,
    Depends is your gq 24v some of the imports are. Local trucks tend to be 12v but you need to check what you have
    Patrol God Stropp's Avatar
    31 Post(s)
    Quote Originally Posted by liftlid View Post
    yes more than likely it will be 12v or 24v if its a shorty import or lwb import.
    Ballarat, Vic
    174 Post(s)
    Several simple ways to check.
    Look at your starter battery(ies).
    If your starter is a single battery you need 12v
    If your starter is two batteries joined together (most likely side by side) you need 24v
    (Do not confuse with an auxillary battery setup which will have a solenoid or similar between the two batteries & most likely not side by side)
    Alternatively remove a headlight globe to see if it’s marked as 12v or 24v.
    If you have a multimeter you could check the voltage across the two battery terminals (+ve on one, -ve on the other) to see if you get 12v or 24v.
  6. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    Stropp (25th September 2014), Zebinc (25th September 2014)
    Sep 2014
    So if i only have 1 battery it will be 12v, correct?
    Yes.
    Regardless of that, 99% you will be 12V, 24V is rare but they are around.
  9. #7
    Ballarat, Vic
    174 Post(s)
    As Winnie says - Yes - Correct.
    You don’t get 24v batteries, they are always made up of two or more lower voltage, most commonly 2 x 12v.
  10. #8
    Apr 2014
    Actually..you can get 24v batteries, my old unimog had a single 24v battery. I was looking I to running one in my Safari to free up the second batt tray for an aux battery...but they are not exactly easy to find here in aus unless you want to use a lithium marine battery
