9th November 2012, 10:43 PM
#11
Ive got a bit of rust comnig through on the roofs sills on my GQ as well, no where near as bad as this but! good work with the repair mate
88 GQ patrol 4.2l Carby 2" suspension, 2" body
9th November 2012 10:43 PM
3rd March 2013, 09:05 AM
#12
being a panelbeater of nearly 30yrs in the trade,id advise anyone with a safari that has gutter rust to get onto it very fast,as they rust really well round that area.
I just done my own wagon,complete replacement of the drivers side,front to back,and a small 2ft long section on the passengers side.I cut mine right back to the bottom spotweldes that holds the roof to the body,as some of the actual guttering was splitting from rust,so i assholed the lot.
if it aint hurting,it aint working.....1991 y60 LWB 24 volt TD42 Safari
3rd March 2013, 10:32 AM
#13
hi fellas do you get any problems with distortion when welding in the repair sections cheers
01 gu td4.2t wagon factory turbo 2" lift, 3" exhaust,snorkel,awning,uhf,egt & boost gauges,16"black round hole dynamic rims with 285 bighorns with more to come, ,air compressor,rear led work lights,winch, ready to fit up
4th March 2013, 11:56 AM
#14
just alternate your welds bud,similar to torqing down a head,and have a rag and cold water close by.It doesnt need seam welding,just spotwelds every cm or so.
I thought while the truck was off the road I might aswell do the rear lower quarter panels,then thought id just chop the bottom 6inches or so off,alot less work and looks a bit better.
10th March 2013, 10:13 PM
#15
14th March 2013, 05:50 AM
#16
Love it. Great job!
Is there any access points from the inside where one could poke a fogging wand into and spray the inside with lanolin/fish oil?
16th September 2014, 01:00 PM
#17
Grouse job mate! i have to get to fixing rust pretty soon and ill probably go about it in a similar way
16th September 2014, 01:49 PM
#18
The Mad Ozzy
www.swat4x4.com
2nd November 2016, 07:03 PM
#19
Did you post any pics as i cant see any - just about to do my sons 94 gq with roof rust - my 96 seems ok -are 94's bad for it?
