10th September 2014, 05:27 PM
Fairey type overdrive for patrol
I know you can get them for early 4 speed patrols but cant seem to find any info on later model 5 speed ones, can anyone help?? it would be an easy way to swap between 33 to 35's without doing the diffs.
Reason: Fixed spelling in title
10th September 2014 05:27 PM
10th September 2014, 06:03 PM
Rotaredom
What ratio is your 5th gear now? Nissan updated all GU Patrols as of 08/2004 with a longer spline main shaft and 5th gear according to Marks 4wd
Would this achieve what your after? http://www.marks4wd.com/mfk730.html
10th September 2014, 08:40 PM
Yeh I have the 11/04 model but I was chasing the lower gearing the fairey type gives you as it gives you a half gear which would be great with the 35's
11th September 2014, 01:33 PM
Fairley were vacuum operated weren't they,
from memory the early Patrol OD was a mechanical lever on the floor
11th September 2014, 02:57 PM
threedogs
another stick 3D, i was very interested in one back in the early 80's for my "other" 4wd.
11th September 2014, 07:18 PM
Stretching the memory but I'm sure it was just a lever to engage/dis-engage.
Mates Rangie had the vacuum diff loc when we went to the Cape in '83
some 60s had them too I think
11th September 2014, 08:44 PM
threedogs
One of my mate's had one on a series 3 landy , separate stick to give it 5th gear on the hwy
12th September 2014, 01:11 AM
#8
No this is a seperate stick to give you a split gearbox so a 1/2 gear between each gear nothing to do with the diff
The Following User Says Thank You to Stropp For This Useful Post:
threedogs (12th September 2014)
26th October 2014, 11:50 AM
#9
just put a 18 speed road ranger in with tall diffs
The Following User Says Thank You to johno1938 For This Useful Post:
